I cannot connect to octopi local IP on Android.
I can access octoprint fine from my desktop. I'm on the same network.
Can't really find anyone else with this issue, so I don't even know where to start.
The octopi.local name is a Bonjour name (see also). I'm not sure if there is a version for Android.
You should be able to connect using the IP address instead.
If you need additional help, please start by uploading a systeminfo bundle and additional information (i.e. details) of your network configuration and the systems involved (including version numbers). Note: The blue text is a link.
FYI, Android has supported mDNS/DNS-SD since late 2021, & it has played well with the mDNS/DNS-SD support on the Pi (avahi-daemon) and Windows (Bonjour) on my network. I can resolve .local addresses from the Android device.
That's good to know. I have a local (DHCP and) DNS server so I connect from my Android devices using my local domain name. However, this doesn't solve @Carson_Harris's issue so without additional information, there's not much we can do.
