When printing via OctoPrint (fresh install), the flow rate is obviously lower than the "correct" amount (sparse lines). Printing via the printer directly does not have this problem.
I think I encountered similar situations before, when I 1) used Repetier to print, or 2) set "in mm^3" for "Filament" on the printer. So I suspect there could be some obvious option to fix this but I overlook.
N/A
Logs
N/A
OctoPrint: Version 1.4.0; OctoPi: The ready-to-go Raspberry Pi image with OctoPrint, Version 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3; Printer: Anet A8; Firmware: Marlin 1.1.9; Flow rate: 100% (unchanged). Slicer: Cura 4.5.0
My gut tells me print speed might be the difference. I would look carefully at any OctoPrint/Repetier startup gcode scripts for anything that sets Fnnn.
Thanks for everyone's attention. After inspecting the previous failed and (relatively) successful prints closely in the next morning, I think Ewald_Ikemann was mostly on the correct path - the real cause was probably the damaged Teflon tube inside the hotend throat. I wanted to update you after having the printer fixed, but I just broke it more so it won't happen in a few days ...
Personally, I cut about two inches of PTFE tubing and that's what I put in the top of my primary extruder assembly. Before, I found that off-brand filament wants to rub on the sides of a standard length of tubing and will often "notch" at the feed gear, then "air print" until I notice the problem.
