I can not close the announcement
I tried everything to get to the bottom of the announcement, but it is not possible
I have a problem closing one of the announcements.
I have not used the printer for some weeks, so there are several update announcements, and the one you can see is getting too long so i can not use the button on the bottom of this announcement to close it.
Try opening the browser dev console (usually F12) and paste this $(".ui-pnotify-container").find("button").eq(1).click(); which (all going well) should "click" the 2nd button which is the button to "mark read".
Personally, I would either
- OSX: Cmd, -
- Windows: Ctl, -
...until everything gets small enough to click it.
And then, I'd probably add Themeify and adjust the default zoom size.
yeah, I've seen these too. @foosel how about a scroll bar or a way to dismiss it at the top?
