I hope I'm doing it right here , if not please move that to the "docker-section"
I installed 2 instances using this guide
both instances are working fine, but MJPG-Streamer is not reachable at the second instance with
redirected port. default-port for the mjpg-streamer is 8080 and it is redirected/forwarded to 8081.
But its not available at 8081, only 8080.
I tried to re-configure the docker composer-file, gave both containers a static IP and the ports
tried to change the order, gave other ports and double checked the firewall-settings.
The instances are reachable at port 5000 and 5001, so all is fine.
No, Octoprint itself is running fine, so no need to
no
OctoPrint version: 1.7.2
printer: Ender3 Pro, Forge-Bot, FLSUN QQS Pro, Prisa i3 MK3is
Firmware: Marlin, Smoothieware, FLSUN own stuff, like Prusa
Browser: Edge, Chrome, Firefox
Operating system: WIndows 10, Windows 11, DietPi
to prevent misunderstandings : Octoprint is working fine, my only problem is : no webcam support in docker container 2, because mjpg is not reachable.
Here is my docker-composer file :
1version: '3.6'
2 services:
3 #####Ender3_Pro
4 Octoprint1:
5 container_name: Ender3
6 image: octoprint/octoprint
7 hostname: Ender3
8 restart: unless-stopped
9 ports:
10 - "5000:5000"
11 - "8080:8080"
12 volumes:
13 - /home/dietpi/docker/octoprint1:/octoprint1
14 environment:
15 - ENABLE_MJPG_STREAMER=true
16 - MJPG_STREAMER_INPUT=-n -d /dev/video0:/dev/video0 -r 1280x720 -f 20
17 devices:
18 #Printer Port
19 - /dev/ttyUSB0:/dev/ttyACM0
20 #Webcam port
21 - /dev/video0:/dev/video0
22
23 #####FLSUN_QQS_pro
24 Octoprint2:
25 container_name: FLSUN
26 image: octoprint/octoprint
27 hostname: FLSUN
28 restart: unless-stopped
29 ports:
30 - "5001:5000"
31 - "8081:8080"
32 volumes:
33 - /home/dietpi/docker/octoprint2:/octoprint2
34 environment:
35 - ENABLE_MJPG_STREAMER=true
36 - MJPG_STREAMER_INPUT=-n -d /dev/video1:/dev/video0 -r 1280x720 -f 30
37 devices:
38 #Printer Port
39 - /dev/ttyUSB1:/dev/ttyACM1
40 #Webcam Port
41 - /dev/video1:/dev/video0
if you have any suggestions, please let me know. I wasted more than a day right now to get this up and running, and its pretty much frustrating.
Regards
MAMEniac.
