My Anycubic Chiron and octoprint will loose connection to each other randomly during a print. I'm running stock firmware on the Chrion 1.3.0 with a Pi4 and octoprint 1.4.0. This typically occurs on longer prints but, haven't been able to nail down any specific % or timing around this.
The print head just stops and everything remains heated until I am able to manually override the printer.
probalby worth noting once the disconnect occurs I am unable to reconnect without rebooting the printer and/or octoprint, sometimes it's both other times it's just the printer.
I use to be running on a Cu-box i4 with armbian and octoprint installed. I still had the same end result IE failed prints in the middle (I did not capture logs at the time). This has since been replace with a pi 4b due to it being a more common hardware used for octoprint. I've reinstalled octoprint a few times on both devices and the problem still persisted. Multiple SD cards have been used ranging from 8GB to 32GB.
USB cable to printer has been flexed and moved to see if there where any disconnects. No disconnects occurred.
New .gcode, as well as testing same .gcode on SD directly in the printer.
Multiple slicers S3D and CURA have been used to produce .gcode with failed prints both which work on the SD card
Tried different baud rates 115200 and 250000
I've captures octoprint.log in DEBUG as well as serial.log and dmesg from the raspberry pi, and terminal output from octopi which all can be found here:
https://drive.google.com/drive/folders/1j0fE2OVDivhjeaJ4z6zgD40LkRNMizd3?usp=sharing
If other logs are needed please let me know which ones and I can set up another print as it'll inevitably fail.
At the time of failing this is/was the configuration:
- Octopirint 1.4.0
- Octopi 0.17.0, running on Raspberry Pi 4 Model B Rev 1.1 (with 5V 3A power supply, I have not seen any power message issues, dmesg have been included)
- Anycubic Chiron stock firmware version 1.3.0
- Stock Anycubic Chiron USB A to USB B
- USB A to USB A shielded running to a Wyze v2 camera on web cam firmware plugged into the Pi
- Chrome browser, was not open at time of failure
- files sliced with CURA on a MAC running 10.15.4, same .gcode works fine on the SD card.
- Currently install plugins can be found on the goole drive in octoprint-installed-plugins.txt
- Connection is set to automatic and typically settles on a buad rate of 250000
- USB cable to printer has the power pin blocked plugged into the pi. However it was not blocked while hooked up to the cu-box i4 though.
