I would like to display the probe temperature from a Triangle Labs P.I.N.D.A 2 probe in Octoprint.
Tried enabling chamber temperature and a second extruder.
Complete Logs
Running on an SKR v1.3 Marlin 2.0.6
Hello @Derrick_Rockwell!
On a Prusa printer, there is command M105 with parameter P to read the PINDA 2 temperature.
So with a plugin it should be possible to display it on the OctoPrint GUI.
You are running a SKR v1.3 with Marlin 2.0.6, so you have to check if M105 or another command/parameter supports reading the PINDA 2 temp.
Hey all, this thread got me thinking about how to get the PINDA temp into a graph easily without messing around with Octo too much.
I am using the "Top Temp" Plug-In for OctoPrint as in this you can create a custom Temperature item, and then once you have selected "From Printer" as the Type, you can select Regexp" to "Probe" from the Pre-Defined Drop-Down Menu Button.
This then creates a nice graph at the top that can be shown on mouse-over to see the PINDA probe temperature.
