Apt update doesn't work and getting no public key
When updating my Octopi/Octoprint server, it just started failing on the octoprint repository and says there is no public key.
@octopi1:~ $ sudo apt update
[sudo] password for rogerwa:
Hit:1 Index of /debian bullseye InRelease
Hit:2 Index of /raspbian bullseye InRelease
Get:3 Index of /debian bullseye InRelease [4,067 B]
Err:3 Index of /debian bullseye InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 418208F07AD011A2
This has been working fine for several months.
Ran this command with the key listed above
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 418208F07AD011A2
Says apt-key is deprecated. Could not find any other solution.
N/A
N/A
octoprint-systeminfo-20240325205200.zip (114.7 KB)
OctoPrint version 1.9.3, OctoPi version 1.0.0, printer Ender 3Pro, firmware, browser, operating system, ... as much data as possible
Raspberry Pi 4, Octoprint 1.9.3, Octopi 1.0.0
Unfortunately, the key for https://apt.octoprint.org/ had to be updated. To update the key on your install, you can do the below (instructions from https://apt.octoprint.org/)
"I get an error on update: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 418208F07AD011A2"
Please re-import the public key, it has been updated:
curl -s --compressed "https://apt.octoprint.org/octoprint.gpg.key" | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/octoprint.gpg > /dev/null
sudo apt update
I used the instructions listed here and it worked, especially the following line:
Awesome thanks.. I will give that a try.
