When checking for updates, Arc Welder plugin is throwing the following errors and states Unknown error while checking for update. please check the logs.
Uninstalled and re-installed to see if that would work, it looks normal until you check for updates and then goes back to the previous. Checked logs and looks like something isn't supplying the proper info from the plugin
Can't run it in safe mode to see if that helps as then you have no plugins
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
octoprint.log (66.7 KB)
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 915714048
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 20.2.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.0
