Arducam 64MP camera with autofocus
Can't get it to work in Octopi with new camera stack. Don't know if it is possible with this camera. Have not seen any recent threads that say it can be done without resorting to Arducam's repackaged Octopi.
Made sure i2c was on using raspi-config. Followed instructions to add enabling of both i2c's in /boot/config.txt.
#ArduCamFocus
dtparam=i2c_vc=on
dtparam=i2c_arm=on
Checked octopi can use a normal raspberry pi camera - it works.
A reboot with the new camera shows:
$ libcamera-hello -list cameras says "No cameras available". vcgencmd get_camera output: supported=1 detected=0, libcamera interfaces=0. Which is discouraging.
Edit: I did not install ArduCAMs "updated drivers". Was not sure if required in 2024. dtoverlay=vc4-kms-v3d right now, not dtoverlay=vc4-kms-v3d,cm=512 as Arducam recommends. Wasn't sure if it would boot with this option without Arducam drivers.
Didn't try yet
octoprint-systeminfo-20240125135539.zip (31.3 KB)
1.9.3 OctoPrint, Build 2023.10.09.154319, based on OctoPi 1.0.0, running on Raspberry Pi 4 Model B Rev 1.5. 8GB RAM, 1 TB SSD, Prusa MK4, Safari, MacOS Sonoma 14.2.1, 36GB RAM, 1TB NVME, M3 Max
