So I discovered the new (to me) printer has a broken SD card reader (as in they actually managed to break the component off the board and I haven't taken it apart to do the rework yet), so I decided to attempt a print via USB. This is a QIDI Tech 1, just like my other printer (which is currently down with a fried mainboard and possibly a fried display and SD card reader as well, thanks to a manufacturer wiring issue - black for +24V and red for 0V from the factory - that led to me hooking up the replacement mainboard with reverse voltage). I'm running the OctoPi 0.15.0 image, which is OctoPrint 1.3.8, I believe.
I can upload the file to OctoPrint and load the file on the printer, but when I attempt to print, I get an error message and OctoPrint disconnects from the printer. Since this is an argument error writing to serial (see log below), the only real step I could think of was to make sure GPX was using the right flavor of gcode (problem exists with either setting), and to post a cry for help.
octoprint.log:
2018-05-15 14:59:57,256 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2018-05-15 14:59:57,259 - octoprint.plugins.GPX - INFO - GPXPrinter created, port:
/dev/ttyACM0, baudrate: 115200
2018-05-15 15:00:01,285 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2018-05-15 15:00:01,287 - octoprint.util.comm - INFO - Changing monitoring state fr
om "Offline" to "Opening serial port"
2018-05-15 15:00:01,299 - octoprint.util.comm - INFO - Changing monitoring state fr
om "Opening serial port" to "Detecting baudrate"
2018-05-15 15:00:01,315 - octoprint.util.comm - INFO - Changing monitoring state fr
om "Detecting baudrate" to "Operational"
2018-05-15 15:00:01,331 - octoprint.util.comm - INFO - M110 detected, setting curre
nt line number to 0
2018-05-15 15:00:03,396 - octoprint.util.comm - INFO - Printer reports firmware nam
e "Sailfish"
2018-05-15 15:00:11,382 - octoprint.util.comm - INFO - Changing monitoring state fr
om "Operational" to "Printing"
2018-05-15 15:00:11,408 - octoprint.util.comm - INFO - M110 detected, setting curre
nt line number to 0
2018-05-15 15:00:11,454 - octoprint.util.comm - ERROR - Unexpected error while writ
ing to serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py",
line 3005, in _do_send_without_checksum
result = self._serial.write(to_send)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GPX/gpxprinter.
py", line 131, in write
self._append(gpx.write("%s" % data))
TypeError: argument 1 must be string without null bytes, not str
2018-05-15 15:00:11,472 - octoprint.util.comm - INFO - Changing monitoring state fr
om "Printing" to "Offline (Error: TypeError: 'argument 1 must be string without nul
l bytes, not str' @ comm.py:_do_send_without_checksum:3005)"
2018-05-15 15:00:11,701 - octoprint.plugins.printhistory - INFO - Can't parse addit
ional parameters from /home/pi/.octoprint/uploads/xyzCalibration_cube.x3g
serial.log (turned on and 5th attempt made):
2018-05-15 15:13:41,931 - Changing monitoring state from "Offline" to "Opening serial port"
2018-05-15 15:13:41,938 - Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6d7eb940>, starting monitor
2018-05-15 15:13:41,948 - Starting baud rate detection
2018-05-15 15:13:41,950 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-05-15 15:13:41,958 - Recv: start
2018-05-15 15:13:41,965 - Changing monitoring state from "Detecting baudrate" to "Operational"
2018-05-15 15:13:41,979 - Recv: Sailfish v7.8
2018-05-15 15:13:41,981 - Send: N0 M110 N0*125
2018-05-15 15:13:41,983 - Recv: echo: gcode to x3g translation by GPX
2018-05-15 15:13:42,018 - Recv: SD init fail
2018-05-15 15:13:42,021 - Recv: T:26 /0 B:14 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2018-05-15 15:13:44,030 - Recv: ok
2018-05-15 15:13:44,038 - Send: N1 M115*39
2018-05-15 15:13:44,043 - Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Sailfish FIRMWARE_VERSION:7.8 FIRMWARE_URL:http://www.sailfishfirmware.com MACHINE_TYPE:r1d EXTRUDER_COUNT:2
2018-05-15 15:13:44,050 - Send: M21
2018-05-15 15:13:44,055 - Recv: ok
2018-05-15 15:13:44,057 - Recv: SD init fail
2018-05-15 15:13:46,966 - Send: M105
2018-05-15 15:13:47,003 - Recv: ok T:27 /0 B:14 /0 T0:27 /0 T1:26 /0 @:0 B@:0
2018-05-15 15:13:51,968 - Send: M105
2018-05-15 15:13:52,005 - Recv: ok T:26 /0 B:14 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2018-05-15 15:13:56,968 - Send: M105
2018-05-15 15:13:57,002 - Recv: ok T:26 /0 B:14 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2018-05-15 15:14:02,003 - Send: M105
2018-05-15 15:14:02,040 - Recv: ok T:26 /0 B:14 /0 T0:26 /0 T1:27 /0 @:0 B@:0
2018-05-15 15:14:04,328 - Changing monitoring state from "Operational" to "Printing"
2018-05-15 15:14:04,360 - Send: N0 M110 N0*125
2018-05-15 15:14:04,362 - Recv: ok
2018-05-15 15:14:04,364 - Send: (@build "xyzCalibration_cube")
2018-05-15 15:14:04,366 - Recv: ok
2018-05-15 15:14:04,368 - Send: N1 M136 (xyzCalibration_cube)*120
2018-05-15 15:14:04,385 - Recv: ok
2018-05-15 15:14:04,387 - Send: ?xyzCalibration_cube???i???0????x
2018-05-15 15:14:04,389 - Unexpected error while writing to serial port: TypeError: 'argument 1 must be string without null bytes, not str' @ comm.py:_do_send_without_checksum:3005
2018-05-15 15:14:04,397 - Changing monitoring state from "Printing" to "Offline (Error: TypeError: 'argument 1 must be string without null bytes, not str' @ comm.py:_do_send_without_checksum:3005)"
2018-05-15 15:14:06,391 - Connection closed, closing down monitor
OctoPrint Terminal:
Recv: start
Recv: Sailfish v7.8
Recv: SD init fail
Recv: ok
Send: N1 M115*39
Send: M21
Recv: ok
Recv: SD init fail
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok
Recv: ok
Recv: ok
Send: ?\x00\x00\x00\x00xyzCalibration_cube\x00?\x00\x00?\x00?\x03i\x01\x00\x00\x14\x00?\x04?\x00\x00\x00\x14\x00?\x00\x00\x00\x00\x00\x00\x00\x000???\x00\x00\x00\x00\x00\x00\x00\x00?\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00x
