I use PSU to shut down printer when idle, when Cura sends a job, Octoprint turns the printer on and tries to connect, but since the printer was down the USB0 port is not available, and I get a connection error. There are no retries done, since port is not available.
When in ~10 sec I press the connect button all works fine, since by the time the port is already available.
Any Ideas how to set 10 sec delay, from power on command till connect command.
