I need your help! Looking to use GPIO to automatically clear print bed and automatically start next print.
I do not currently see any plugins that cater to all of these needs. I need to use a GPIO pin as an output to trigger an print bed clearing mechanism, then once the print bed clearing mechanism is completed, I need to us another GPIO pin as an input to start the next print. It would also be great to have an additional output pin available for a print fault indicator.
Using Raspberry Pi 4 with general purpose relay IO module.
Using with the following printers:
Prusa I3 MK3S+
Markforged Mark2
Markforged X7
Markforged ONYX1
If this solution does not exist, I will reward someone who can help create a solution.
This is a new project, and other than the printers, I can use whatever hardware necessary to complete this job.
Thanks!
