I created and saved a backup from a previous version of Octoprint (running on Octopi) using the command line backup tool. After reinstalling Octopi, I moved the backup to the pi and attempted a restore using the backup:restore command, at which point it told me Not an OctoPrint backup, lacks metadata.json. I went to take a look at the backup, and... it only contains a single (large) .img file.
The backup is named octopi-1.1.0-1.11.2-20250610114348.zip and contains only octopi-1.1.0-1.11.2-20250610114348.img.
After some research, I take it this is Not Normal. ![]()
Mostly googling around to see if anyone else has ended up with a backup file that has an img file in it instead of the usual (I now realize) set of files and directories. Didn't find anything, unfortunately.
N/A
N/A
octoprint-systeminfo-20250719183620.zip (7.3 KB)
Note that all I've done is click through the setup dialog.
Octoprint Version 1.11.2
Octopi Build 2025.06.10.114348 with "webcamd", based on OctoPi 1.1.0, running on Raspberry Pi 4 Model B Rev 1.2
Freshly flashed.
The full restore command:
pi@octopi:~ $ ./oprint/bin/octoprint plugins backup:restore ~/octopi-1.1.0-1.11.2-20250610114348.zip
Initializing settings & plugin subsystem...
Removing temporary zip
Restoring from /tmp/tmphsfu4_iv failed
