After installation of new version 1.3.10 on Octopi 0.13.0 and RPi 3 and Dual Builder printer I try to make backup of setting I recieved this Error message
Creating the backup failed
OctoPrint could not create your backup. Please consult octoprint.log for details. Error:
**What did you already try to solve it?**Restart of OctoPrint, different setup of Backup addon.
In octoprint.log I found:
2018-12-11 16:38:14,556 - octoprint.plugins.backup - ERROR - Error while creating backup zip
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup/init.py", line 610, in _create_backup
raise InsufficientSpace()
InsufficientSpace
but on sd card I have more than 4.3 GB and plugin don´t ask for saving path for saving to flash.
The backup file is stored on the SD card and you can it download after creating.
Depending on the parameters you set and the amount of plugins, the backup file can get quite large. Especial when you have some large time lapse files to store.
pi@octopiBuilder:~ $ df -h
Souborový systém Velikost Užito Volno Uži% Připojeno do
/dev/root 15G 9,6G 4,4G 69% /
devtmpfs 426M 0 426M 0% /dev
tmpfs 430M 0 430M 0% /dev/shm
tmpfs 430M 6,3M 424M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 430M 0 430M 0% /sys/fs/cgroup
/dev/mmcblk0p1 60M 22M 39M 37% /boot
tmpfs 86M 4,0K 86M 1% /run/user/1000
pi@octopiBuilder:~ $ ls -l ~/.octoprint/uploads
celkem 4340204
-rw-r--r-- 1 pi pi 5170559 pro 4 12:52 Anet.gcode
-rw-r--r-- 1 pi pi 10260695 kvě 22 2018 Arertacni_roh_dil_B.gcode
-rw------- 1 pi pi 6759079 říj 16 2017 Arertacni_roh_dil_EZ950_55_inch.gcode
-rw------- 1 pi pi 22694546 lis 2 2017 Aretacni_roh_-_Arertacni_roh_dil_B-1.gcode
-rw------- 1 pi pi 1233920 lis 2 2017 Aretacni_roh_55_65EZ_950_-_Aretacni_roh_dil_A_55_65EZ950-1.gcode
-rw------- 1 pi pi 2055708 čen 23 2017 Batman_Spinner.gcode
-rw------- 1 pi pi 26661014 srp 10 2017 blok_na_aku_-_telo_a_viko.gcode
-rw------- 1 pi pi 2712533 srp 17 2016 Bocmice_na_nylon.gcode
-rw------- 1 pi pi 3949447 srp 4 2016 Bocnice.gcode
-rw------- 1 pi pi 4609448 srp 2 2017 Builder_hacek_kabelu_OLED_v4.gcode
-rw-r--r-- 1 pi pi 653391 zář 13 11:37 builder_Vlozka_BR_paleta_V1.gcode
-rw------- 1 pi pi 9734198 srp 2 2017 Builder_V2_hacek_kabelu_OLED_v4.gcode
-rw------- 1 pi pi 11017203 úno 12 2018 builder_4_kratsi.gcode
-rw------- 1 pi pi 3748004 pro 2 2016 bull_horn.gcode
-rw------- 1 pi pi 54815732 bře 28 2017 Bures.gcode
-rw------- 1 pi pi 1559961 pro 7 2017 cameramount.gcode
-rw-r--r-- 1 pi pi 2374469 čen 5 2018 cast_spony.gcode
-rw------- 1 pi pi 1167481 srp 5 2016 cdTray_v5.gcode
-rw------- 1 pi pi 509040 pro 21 2017 celist_gripper.gcode
-rw------- 1 pi pi 2230480 led 9 2018 celist_gripper_2.gcode
-rw-r--r-- 1 pi pi 25797272 říj 17 12:38 Centrovani_TV__pouzdro.gcode
-rw------- 1 pi pi 17268496 dub 11 2018 Centrovani_TV__pouzdro_sada_tri.gcode
-rw------- 1 pi pi 1886152 bře 17 2017 Coffe.gcode
-rw-r--r-- 1 pi pi 3823860 lis 9 14:58 cumprlik_builder.gcode
-rw------- 1 pi pi 16849239 zář 1 2016 C2_New.gcode
-rw------- 1 pi pi 78096465 led 31 2017 C_40.gcode
-rw------- 1 pi pi 75565712 úno 6 2017 C_55.gcode
-rw------- 1 pi pi 334215 čen 15 2017 Deckel.gcode
-rw------- 1 pi pi 2714529 čen 15 2017 Deckel_t1_v2.gcode
-rw-r--r-- 1 pi pi 1575965 lis 19 13:14 derkovaci_pripravek.gcode
-rw-r--r-- 1 pi pi 6411794 čen 26 15:12 Dil_A.gcode
-rw------- 1 pi pi 15305445 led 25 2018 Dil.gcode
-rw-r--r-- 1 pi pi 5925312 kvě 3 2018 Dil1.gcode
-rw------- 1 pi pi 9174975 lis 3 2016 Dil1_Kubrt.gcode
-rw------- 1 pi pi 4779285 zář 12 2016 Dil10.gcode
-rw-r--r-- 1 pi pi 2306102 lis 1 15:25 DKS.gcode
-rw------- 1 pi pi 1831670 bře 8 2018 Domecek_kvalt.gcode
-rw------- 1 pi pi 8031994 lis 8 2017 Domecek_pokus.gcode
-rw------- 1 pi pi 1587358 bře 7 2018 Domek_lamel.gcode
-rw------- 1 pi pi 15461893 bře 15 2018 Domek_lamel_10_kousku.gcode
-rw------- 1 pi pi 15461893 bře 15 2018 Domek_lamel_10_ks.gcode
-rw------- 1 pi pi 11597108 dub 5 2017 Doraz_levy(2).gcode
-rw-r--r-- 1 pi pi 1139329 lis 21 11:53 doraz_L9.gcode
-rw-r--r-- 1 pi pi 7233549 lis 28 14:35 doraz_L9_p5.gcode
-rw------- 1 pi pi 7210446 pro 13 2017 Doraz_PEM_SK_15_003.gcode
-rw------- 1 pi pi 1418709 úno 1 2017 Doraz_s_pinem.gcode
-rw------- 1 pi pi 5189285 úno 24 2017 Doraz_s_pinem_pravy_builder.gcode
-rw------- 1 pi pi 1354474 úno 1 2017 Doraz_s_pinem(2).gcode
-rw------- 1 pi pi 2916119 dub 6 2017 Dorazy.gcode
-rw-r--r-- 1 pi pi 54946230 pro 10 11:17 dorazy_L9_levej.gcode
-rw------- 1 pi pi 1611836 zář 4 2017 Drk_hadice_na_roubovku_prav_prodlouen_2.gcode
-rw------- 1 pi pi 710308 čen 13 2017 Druhy_pripravek_pro_frezovani_voditka_pasu_B.gcode
-rw------- 1 pi pi 26842717 bře 7 2017 drzak_baleni_E_75_inch.gcode
-rw------- 1 pi pi 3255866 led 8 2018 drzak_Brodit_Huawei_mezikus_.gcode
-rw------- 1 pi pi 1732895 pro 20 2017 drzak_Brodit_Xiaomi_.gcode
-rw------- 1 pi pi 4970823 led 24 2017 Drzak_Builder_sestava.gcode
-rw-r--r-- 1 pi pi 4140925 zář 18 17:03 drzak_cedulek_PEH_4ks_Builder_se_sukni.gcode
-rw-r--r-- 1 pi pi 4099837 zář 18 15:04 drzak_cedulek_PEH_4ks.gcode
-rw------- 1 pi pi 1490046 úno 7 2018 Drzak_cidla_pro_pouzdro_pinu_V2.gcode
-rw------- 1 pi pi 5781190 úno 7 2018 Drzak_cidla_pro_pouzdro_pinu_4_kusy.gcode
-rw------- 1 pi pi 5875990 lis 13 2017 drzak.gcode
-rw------- 1 pi pi 1661853 zář 1 2017 Drzak_hadice.gcode
-rw------- 1 pi pi 1063498 zář 5 2017 Drzak_hadice_na.gcode
-rw------- 1 pi pi 16041532 zář 26 2017 Drzak_hadice_na_sroubovaku______.gcode
-rw------- 1 pi pi 1571778 zář 4 2017 Drzak_hadice_na_sroubovaku_pravy_prodlouzeny.gcode
-rw------- 1 pi pi 1103267 zář 5 2017 Drzak_hadice_na_sroubovaku_pravy_prodlouzeny_na_spojku.gcode
-rw------- 1 pi pi 2873482 zář 7 2017 Drzak_hadice_na_sroubovaku_pravy_prodlouzeny_na_spojku_2ks.gcode
-rw------- 1 pi pi 1512901 zář 1 2017 Drzak_hadice_na_sroubovaku_pravy_pro_tisk.gcode
-rw------- 1 pi pi 4082498 zář 26 2017 Drzak_hadice_na_sroubovaku_sada_na_linku.gcode
-rw------- 1 pi pi 9294098 lis 1 2017 Drzak_hadice_01_11.gcode
-rw------- 1 pi pi 2665463 zář 1 2017 Drzak_hadice_2_a_2.gcode
-rw-r--r-- 1 pi pi 5186633 říj 18 10:49 drzak_kabelu.gcode
-rw-r--r-- 1 pi pi 7684380 čen 26 11:28 drzak_kabelu_wi-fi_cep.gcode
-rw-r--r-- 1 pi pi 616748 říj 22 12:38 drzak_kamery_IT.gcode
-rw------- 1 pi pi 8783655 zář 20 2017 Drzak_Light.gcode
-rw-r--r-- 1 pi pi 11143917 čec 20 09:18 Drzak_misky.gcode
-rw------- 1 pi pi 30312912 kvě 15 2017 drzak_nohy.gcode
-rw------- 1 pi pi 7347054 kvě 12 2017 drzak_nohy_nastavce_21mm.gcode
-rw-r--r-- 1 pi pi 2950003 zář 19 07:56 drzak_PEH.gcode
-rw------- 1 pi pi 29705974 bře 27 2017 drzak_pistu(5).gcode
-rw------- 1 pi pi 4636901 led 30 2018 Drzak_pouzdra_pinu.gcode
-rw------- 1 pi pi 8145226 bře 16 2017 Drzak_rucniho_ventilu_4.gcode
-rw------- 1 pi pi 1006534 led 31 2018 Drzak_sensoru_BALLUF_BES00...3mmSTL.gcode
-rw-r--r-- 1 pi pi 4793315 čen 5 2018 Drzak_SMC.gcode
-rw-r--r-- 1 pi pi 9732929 čen 6 2018 Drzak_SMC_2ks.gcode
-rw-r--r-- 1 pi pi 1044430 říj 9 08:23 drzak_VSi_V_D_-_Drzak_VSi_V_D_horni_dil.gcode
-rw-r--r-- 1 pi pi 3646414 čen 5 2018 drzak_vzpery.gcode
-rw------- 1 pi pi 5605542 lis 23 2017 drzak_v2.gcode
-rw-r--r-- 1 pi pi 2850612 kvě 31 2018 drzaky.gcode
-rw-r--r-- 1 pi pi 56785896 říj 23 12:31 drzaky_kabelu.gcode
-rw------- 1 pi pi 9359233 bře 14 2017 drzak_zamecku_G1_65_inch.gcode
-rw------- 1 pi pi 8198594 čen 15 2017 drzak_zamecku_G1_65_inch_v4.gcode
-rw-r--r-- 1 pi pi 16725907 kvě 31 2018 drzak_zastrcky_OLED.gcode
-rw------- 1 pi pi 2017716 čen 22 2017 drzak_zastrcky_OLED_2.gcode
-rw------- 1 pi pi 3662922 srp 8 2016 Drzak_zdroje.gcode
-rw------- 1 pi pi 2122367 bře 9 2017 Drzak_50_inch.gcode
-rw------- 1 pi pi 1845283 pro 6 2017 drzatko_roleta.gcode
-rw------- 1 pi pi 2430542 pro 6 2017 drzatko_roleta2.gcode
-rw------- 1 pi pi 2447337 pro 6 2017 drzatko_roleta3.gcode
-rw------- 1 pi pi 2447361 pro 6 2017 drzatko_roleta4.gcode
-rw------- 1 pi pi 2205625 kvě 12 2017 drzik_kladky.gcode
-rw------- 1 pi pi 4010106 kvě 15 2017 drzik_kladky_mul.gcode
-rw------- 1 pi pi 6264786 kvě 17 2017 EGI_PANEL_WARPING_MEASUREMENT_jig_CZ_R.gcode
-rw------- 1 pi pi 13684521 říj 5 2017 EZ950_65_inch.gcode
-rw------- 1 pi pi 113125536 bře 23 2017 E1_-_50_inch_2_sady.gcode
-rw------- 1 pi pi 108821555 bře 19 2017 E1_58_65_dve_sady.gcode
-rw------- 1 pi pi 59895366 bře 23 2017 E_1_58_65_1_sada.gcode
-rw------- 1 pi pi 13779620 bře 26 2018 Fit_Ball_valve_v4.gcode
-rw-r--r-- 1 pi pi 2000487 čen 18 08:46 fixace.gcode
-rw-r--r-- 1 pi pi 5604671 čen 19 07:51 fixace_nohou.gcode
-rw-r--r-- 1 pi pi 2288911 čen 18 11:17 fixace_nohy.gcode
-rw------- 1 pi pi 2172021 srp 29 2016 Fixacni_roh_-_3_polohy.gcode
-rw-r--r-- 1 pi pi 1980987 lis 12 14:22 FX700_-_lepeni_LED_baru_pritlak_LED_22mm.gcode
-rw------- 1 pi pi 1348710 dub 4 2018 FX700_-_lepeni_LED_baru_pritlak_LED_22mm_ted.gcode
-rw------- 1 pi pi 399283 dub 10 2018 FX700_-_lepeni_LED_baru_pritlak_LED_3kusy.gcode
-rw------- 1 pi pi 122527 dub 10 2018 FX700_pokus.gcode
-rw-r--r-- 1 pi pi 37438515 kvě 11 2018 FX800_BTM.gcode
-rw-r--r-- 1 pi pi 1346153 čec 4 12:31 FX800_BTM_oprava.gcode
-rw------- 1 pi pi 1918344 bře 26 2018 FX800_BTM_ornament_center._jig.gcode
-rw------- 1 pi pi 1095049 dub 5 2018 FX800_BTM_plastic_ornament_center._jig.gcode
-rw-r--r-- 1 pi pi 8006031 kvě 14 2018 FX800_-_Petr.gcode
-rw-r--r-- 1 pi pi 2687540 kvě 15 2018 FX800_2ks.gcode
-rw------- 1 pi pi 8864689 bře 28 2018 Ginny.gcode
-rw------- 1 pi pi 2332737 bře 28 2018 ginny_wand_tip.gcode
-rw------- 1 pi pi 34954953 bře 13 2017 G58_2_x_sada.gcode
-rw------- 1 pi pi 817956 čec 26 2017 hacek_kabelu_OLED_V2.gcode
-rw------- 1 pi pi 3811969 čec 27 2017 hacek_kabelu_OLED_v3.gcode
-rw------- 1 pi pi 42644843 srp 1 2017 hacek_kabelu_OLED_v4.gcode
-rw------- 1 pi pi 1696675 čec 21 2017 hacek_kabelu_OLED_x2.gcode
-rw------- 1 pi pi 1815094 čec 21 2017 hacek_kabelu_OLED_x2_simply.gcode
-rw------- 1 pi pi 1790305 čec 21 2017 hacek_kabelu_OLED_2ks.gcode
-rw------- 1 pi pi 3295219 čec 28 2017 hacek_kab.gcode
-rw------- 1 pi pi 2276757 čen 23 2017 hacky.gcode
-rw------- 1 pi pi 3380179 kvě 23 2017 Hak.gcode
-rw------- 1 pi pi 560400 čen 23 2017 Hek.gcode
-rw-r--r-- 1 pi pi 9205730 čec 11 16:18 Horni_rolna.gcode
-rw-r--r-- 1 pi pi 1862976 čen 7 2018 Intex_lucka.gcode
-rw------- 1 pi pi 28451112 led 4 2018 Jezdec.gcode
-rw-r--r-- 1 pi pi 34879978 čen 19 12:38 JIG_-_NOHY.gcode
-rw------- 1 pi pi 136531 srp 29 2017 Kalibr_na_vysku_plechu_M3_osazeny_cerny.gcode
-rw------- 1 pi pi 96616 zář 6 2017 Kalibr_na_vysku_plechu_M3_stribrny_2-7_mm.gcode
-rw------- 1 pi pi 268903 srp 30 2016 kalibr_V1.gcode
-rw------- 1 pi pi 18990141 pro 18 2017 kamen_kratsi.gcode
-rw------- 1 pi pi 21646192 led 3 2018 kamen_kratsi_2.gcode
-rw------- 1 pi pi 18521289 pro 15 2017 kameny_Lukas.gcode
-rw------- 1 pi pi 28058162 pro 15 2017 Kameny_matky.gcode
-rw------- 1 pi pi 84849583 lis 16 2016 kladka2_pas_(opraveno).gcode
-rw------- 1 pi pi 2429896 kvě 11 2017 Klema_na_satelit.gcode
-rw------- 1 pi pi 14500169 zář 19 2017 klicka_baleni.gcode
-rw-r--r-- 1 pi pi 6567320 říj 12 16:04 klicka_baleni_Michal.gcode
-rw-r--r-- 1 pi pi 6451862 říj 10 08:44 klicka_baleni_4_builder.gcode
-rw-r--r-- 1 pi pi 2267859 říj 22 11:57 klic_na_GT-P5LS.gcode
-rw-r--r-- 1 pi pi 871413 říj 8 10:27 klinek_pro_technicky.gcode
-rw-r--r-- 1 pi pi 345099 říj 8 12:36 klinek_pro_technickyV2.gcode
-rw------- 1 pi pi 11776873 kvě 16 2017 Klin.gcode
-rw------- 1 pi pi 3439753 zář 16 2016 Kolo.gcode
-rw------- 1 pi pi 2075924 srp 21 2017 Kosticka.gcode
-rw------- 1 pi pi 346769 srp 14 2017 Kosticky.gcode
-rw------- 1 pi pi 358272 srp 14 2017 Kosticky_najednou.gcode
-rw-r--r-- 1 pi pi 151541 pro 20 2016 Kostka.gco
-rw------- 1 pi pi 3281686 led 22 2018 Kostka_L-_pondeli.gcode
-rw------- 1 pi pi 3212995 led 22 2018 Kostka_P-_pondeli.gcode
-rw------- 1 pi pi 744684 pro 20 2016 Kostka.STL
-rw------- 1 pi pi 3301122 led 22 2018 Kostka_stredni.gcode
-rw------- 1 pi pi 22332765 pro 21 2016 kostka_1_40EX600.gcode
-rw------- 1 pi pi 6415312 led 17 2017 Krabicka_na_RPi_kameru_s_prisvicenim.gcode
-rw------- 1 pi pi 3041762 pro 1 2016 Krabicka__termostat.gcode
-rw------- 1 pi pi 973099 bře 19 2018 Kridla.gcode
-rw------- 1 pi pi 2690975 lis 9 2017 kryt_domecku_pokus.gcode
-rw------- 1 pi pi 5430994 lis 8 2017 Kryt_jezdce.gcode
-rw-r--r-- 1 pi pi 2792609 led 23 2017 Krytka_krabicky_na_HDMI_redukci_s_prisvicenim.gco
-rw------- 1 pi pi 1315410 led 23 2017 Krytka_krabicky_na_HDMI_redukci_s_prisvicenim.gcode
-rw------- 1 pi pi 385584 led 23 2017 Krytka_krabicky_na_HDMI_redukci_s_prisvicenim.STL
-rw------- 1 pi pi 1297037 kvě 23 2017 Krytka_podavace_podavace.gcode
-rw------- 1 pi pi 146315 pro 7 2017 Krytka_svorkovnice_4mm.gcode
-rw------- 1 pi pi 185573 pro 11 2017 Krytka_svorkovnice_4mm_koncova.gcode
-rw------- 1 pi pi 3692168 pro 21 2017 Krytky.gcode
-rw------- 1 pi pi 503783 srp 11 2017 Kryt_podavace_podavace_builder.gcode
-rw------- 1 pi pi 68584 dub 18 2017 kryt_remenu.STL
-rw------- 1 pi pi 34070695 led 20 2018 Kryt_valeckove_trate.gcode
-rw-r--r-- 1 pi pi 1264348 čen 13 2018 K_tisku.gcode
-rw------- 1 pi pi 13137111 lis 9 2017 Laco_65EZ950_ACM_L.gcode
-rw------- 1 pi pi 7256573 pro 18 2017 lalala.gcode
-rw------- 1 pi pi 16139817 bře 26 2018 Lukas_noc.gcode
-rw------- 1 pi pi 57361897 dub 6 2017 luzka.gcode
-rw------- 1 pi pi 13754456 úno 8 2017 luzko_E_50_inch.gcode
-rw------- 1 pi pi 6186108 úno 9 2017 Luzko_E_58_65_inch.gcode
-rw------- 1 pi pi 77018956 dub 7 2017 Luzko_E_58_65_inch_2.gcode
-rw-r--r-- 1 pi pi 1106065 čen 18 12:09 Luzko.gcode
-rw-r--r-- 1 pi pi 2157605 kvě 2 2018 Luzko_mechanika.gcode
-rw-r--r-- 1 pi pi 14784305 čen 18 12:19 Luzko_noha.gcode
-rw------- 1 pi pi 670403 úno 26 2018 luzko(3).gcode
-rw-r--r-- 1 pi pi 37790820 čen 27 14:10 Madlo_na_vrtacku.gcode
-rw------- 1 pi pi 2493669 lis 14 2017 Maska.gcode
-rw------- 1 pi pi 1112153 zář 29 2016 Maska_15_001.gcode
-rw------- 1 pi pi 699153 čec 29 2016 Maska_15_-_005.gcode
-rw------- 1 pi pi 2344075 srp 18 2016 Matice_-_nylon.gcode
-rw-r--r-- 1 pi pi 2253037 čec 24 08:22 MB124.gcode
-rw------- 1 pi pi 5947313 říj 19 2016 MB124_plech_pasu_kryt_spodni.gcode
-rw------- 1 pi pi 1782736 pro 20 2017 mezidil_na_gripper.gcode
-rw------- 1 pi pi 4054777 led 25 2018 mezidil_na_gripper_M10iA6L-sroubovak.gcode
-rw------- 1 pi pi 13460060 pro 19 2017 MHSL3_32D_M9BV_14_0_Print_(opraveno).gcode
-rw------- 1 pi pi 6437733 pro 19 2017 MHS3_32C_M9BV_X84_8_0_tisk.gcode
-rw-r--r-- 1 pi pi 37960270 lis 29 14:29 Michal_2.gcode
-rw------- 1 pi pi 8043186 led 25 2017 Mim....gcode
-rw------- 1 pi pi 2029485 pro 9 2016 minion2.gcode
-rw------- 1 pi pi 567693 pro 5 2017 MI1.gcode
-rw-r--r-- 1 pi pi 15829100 zář 11 07:35 ML.gcode
-rw-r--r-- 1 pi pi 9099491 čen 25 09:02 ML_luzko_kyvne_2018_prt.gcode
-rw-r--r-- 1 pi pi 7037118 čen 11 2018 ML_luzko_prt.gcode
-rw-r--r-- 1 pi pi 10419860 čen 12 2018 ML_luzko_v2_prt.gcode
-rw-r--r-- 1 pi pi 10836107 zář 6 14:47 ML_luzko_V5_prt.gcode
-rw------- 1 pi pi 1375714 bře 12 2018 Monitor.gcode
-rw------- 1 pi pi 4729949 zář 6 2016 Montaz_komplet_stojanu_W4_-_horni_zkosena.gcode
-rw-r--r-- 1 pi pi 685903 čen 15 07:51 montaz_WIFI_od_Japonce_V2.gcode
-rw------- 1 pi pi 21433901 bře 8 2018 M8.gcode
-rw-r--r-- 1 pi pi 808234 říj 18 14:09 najezdovy_vymezovac_2mm.gcode
-rw-r--r-- 1 pi pi 14374617 dub 16 2018 NECK_BASE-f3.gcode
-rw------- 1 pi pi 16579768 led 16 2018 NECK_BASE_p.gcode
-rw------- 1 pi pi 8094081 led 12 2018 NeedleFileCase.gcode
-rw------- 1 pi pi 4744372 čen 5 2017 new_EGI_PANEL_WARPING_MEASUREMENT_jig_CZ_P.gcode
-rw------- 1 pi pi 3070029 říj 27 2017 Norton_1.gcode
-rw-r--r-- 1 pi pi 1151921 dub 12 2018 Nova_data.gcode
-rw-r--r-- 1 pi pi 3805691 kvě 3 2018 Nozicka.gcode
-rw------- 1 pi pi 23166239 dub 4 2017 Nozicka_s_matici.gcode
-rw------- 1 pi pi 69167 čen 28 2017 nozicka_spinace_klima.gcode
-rw------- 1 pi pi 22366705 led 24 2017 nurdle_frnt_(opraveno).gcode
-rw------- 1 pi pi 4565012 srp 24 2017 ochrany_doraz.gcode
-rw------- 1 pi pi 1582033 bře 2 2018 op55.gcode
-rw-r--r-- 1 pi pi 2376774 kvě 17 2018 osvetleni_SPZ.gcode
-rw------- 1 pi pi 3406458 srp 9 2017 ovladac_zaluzii.gcode
-rw-r--r-- 1 pi pi 38761580 čec 9 13:43 OwlReDo1.gcode
-rw-r--r-- 1 pi pi 21883435 čec 12 12:17 Owl_2.gcode
-rw------- 1 pi pi 13911095 zář 18 2017 panel.gcode
-rw------- 1 pi pi 2964669 zář 30 2016 Pant_maska.gcode
-rw-r--r-- 1 pi pi 1285208 lis 8 09:46 Panty_-_oprava.gcode
-rw------- 1 pi pi 1975999 čec 15 2016 Pant_zakladna_a_maska__po_jednom.gcode
-rw------- 1 pi pi 4442672 čec 18 2016 Pant_zakladna_a_maska_x2_po_jednom.gcode
-rw------- 1 pi pi 4251384 zář 6 2016 Pant_zakladna_upraveny.gcode
-rw------- 1 pi pi 3688390 čec 14 2016 Pant_zakladna(6).gcode
-rw-r--r-- 1 pi pi 20706896 čec 16 12:45 pedal_rohy.gcode
-rw-r--r-- 1 pi pi 4775344 lis 5 10:31 PEM_18_065_02.gcode
-rw------- 1 pi pi 3570225 bře 5 2018 peta_builder.gcode
-rw------- 1 pi pi 2333163 bře 5 2018 peta_builder_2.gcode
-rw-r--r-- 1 pi pi 2483526 lis 16 12:26 Piny.gcode
-rw-r--r-- 1 pi pi 611432 čec 4 11:24 podlozka_izol.gcode
-rw------- 1 pi pi 3533796 úno 28 2017 podlozka_krajni_C_55_Builder_Slic3r_honeycomb_25proc.gcode
-rw-r--r-- 1 pi pi 2751963 bře 1 2017 podlozka_krajni_C_55_cura.gco
-rw------- 1 pi pi 8654084 led 17 2017 podlozka_krajni_C_55.gcode
-rw-r--r-- 1 pi pi 3111200 bře 1 2017 podlozka_krajni_C_55_slic3r_bundle.gco
-rw-r--r-- 1 pi pi 3385190 bře 1 2017 podlozka_krajni_C_55_slic3r.gco
-rw------- 1 pi pi 153284 bře 1 2017 podlozka_krajni_C_55.STL
-rw------- 1 pi pi 4721529 bře 15 2017 Podlozka_o.gcode
-rw------- 1 pi pi 9457365 srp 25 2016 Podlozka_pod_drzak_cidla.gcode
-rw------- 1 pi pi 1509519 bře 26 2018 podlozka_pod_pist.gcode
-rw------- 1 pi pi 1265371 zář 15 2016 podlozka_pod_senzor.gcode
-rw------- 1 pi pi 35194508 bře 16 2017 Podlozka_pod_upinku_G1_65_inch.gcode
-rw------- 1 pi pi 24835843 led 26 2018 Podlozka_pod_upinku_18C1.gcode
-rw------- 1 pi pi 11929730 úno 7 2017 podlozka_stredni_55_buider.gcode
-rw------- 1 pi pi 40234711 led 11 2017 podlozky_C_40_0-4.gcode
-rw------- 1 pi pi 59577663 bře 10 2017 Podlozky_pod_upinky_G1.gcode
-rw------- 1 pi pi 2930417 led 18 2018 Podpera_bocni_hlubsi_drazka_-_technicke.gcode
-rw------- 1 pi pi 3616420 úno 12 2018 Podpera_horni.gcode
-rw-r--r-- 1 pi pi 3162439 čen 4 2018 podpera_knofliku_bez_drazky.gcode
-rw-r--r-- 1 pi pi 2011483 čen 4 2018 podpera_knofliku_bez_drazky_V2.gcode
-rw------- 1 pi pi 857880 srp 26 2016 Podpera_masky_15-037.gcode
-rw------- 1 pi pi 4295282 říj 4 2016 Podpera_pod_stojan_58DX700_n1_pravy.gcode
-rw------- 1 pi pi 1991927 úno 11 2018 Podpera_prava.gcode
-rw------- 1 pi pi 1320530 pro 20 2016 Podpera_W2_50_palcu_horni_pokus-2-8.gcode
-rw------- 1 pi pi 657355 zář 14 2016 podperny_sloupek_58_inch.gcode
-rw------- 1 pi pi 8867305 říj 27 2017 Podstava_termovize.gcode
-rw-r--r-- 1 pi pi 1457070 lis 2 12:01 pojezd.gcode
-rw-r--r-- 1 pi pi 1428828 lis 2 07:06 pojezd_-_kostka2-1.gcode
drwxr-xr-x 2 pi pi 4096 pro 19 2016 Pokus
-rw------- 1 pi pi 3203289 zář 18 2017 pokus_65_inch.gcode
-rw------- 1 pi pi 255072 pro 5 2016 Polep_ovladace.gcode
-rw------- 1 pi pi 377277 pro 5 2016 Polep_ovladace0-1.gcode
-rw------- 1 pi pi 12386060 úno 1 2018 Pouzdro_pinu.gcode
-rw------- 1 pi pi 14330299 úno 13 2018 Pouzdro_pinu_tisk_posledni.gcode
-rw------- 1 pi pi 13878255 úno 15 2018 Pouzdro_pinu_tisk_v_predu.gcode
-rw------- 1 pi pi 13328535 úno 8 2018 Pouzdro_pinu_v_zadu.gcode
-rw------- 1 pi pi 9051749 úno 6 2018 Pouzdro_pinu_V2.gcode
-rw------- 1 pi pi 12124264 úno 2 2018 Pouzdro_pinu2.gcode
-rw------- 1 pi pi 12325918 úno 2 2018 Pouzdro_pinu4.gcode
-rw-r--r-- 1 pi pi 23834539 lis 6 07:59 Pouzdro_unasece.gcode
-rw-r--r-- 1 pi pi 7272884 čec 9 09:20 pouzkyvcz250.gcode
-rw------- 1 pi pi 3425977 úno 12 2018 pozice_1_2.gcode
-rw------- 1 pi pi 1212413 lis 13 2017 Pozicni_pin_vymene_masky.gcode
-rw------- 1 pi pi 2203783 led 15 2018 Pozicni_pin_vymene_masky_V2.gcode
-rw------- 1 pi pi 201536 kvě 16 2017 prepravka.gcode
-rw------- 1 pi pi 26248848 srp 31 2017 prilozka_krize.gcode
-rw------- 1 pi pi 3133854 dub 18 2017 prilozka_krize-montaz_65-75EX750-780.gcode
-rw-r--r-- 1 pi pi 2835349 dub 12 2017 pripravek_pro_kontrolu_der_v_panelu.gco
-rw------- 1 pi pi 60484 dub 12 2017 pripravek_pro_kontrolu_der_v_panelu.STL
-rw-r--r-- 1 pi pi 5933792 kvě 30 2018 Pro_L_0455EZ950_EGI.gcode
-rw------- 1 pi pi 678259 úno 28 2018 Pruchodka_BMW.gcode
-rw-r--r-- 1 pi pi 2365448 říj 30 10:45 prut.gcode
-rw------- 1 pi pi 5680264 čen 3 2017 Raminko.gcode
-rw------- 1 pi pi 287647 srp 18 2016 rear_casette_cleaner.gcode
-rw------- 1 pi pi 12371450 led 17 2018 redukce_bruska.gcode
-rw------- 1 pi pi 827198 srp 24 2016 redukce_drzaku_pro_panel.gcode
-rw------- 1 pi pi 18577150 čec 14 2017 Redukce.gcode
-rw------- 1 pi pi 11730827 led 18 2018 redukce_hoblik.gcode
-rw-r--r-- 1 pi pi 14459519 říj 25 14:21 Redukce_na_klapku.gcode
-rw-r--r-- 1 pi pi 3670043 čen 22 11:01 redukce_na_vysavaceeee.gcode
-rw-r--r-- 1 pi pi 7322000 čec 20 10:32 redukce_na_vysavac_V2.0.gcode
-rw------- 1 pi pi 48726 čen 20 2017 rezaci_doraz.gcode
-rw------- 1 pi pi 3018063 led 20 2017 Ribbon_Stand_35d.gcode
-rw-r--r-- 1 pi pi 3432768 kvě 21 2018 roh_aretace_2018_s_ruckou.gcode
-rw-r--r-- 1 pi pi 3804566 kvě 22 2018 roh_aretace_2018_s_rukou.gcode
-rw------- 1 pi pi 1198730 kvě 16 2017 roh.gcode
-rw------- 1 pi pi 2045856 čec 14 2016 Roh_levy.gcode
-rw------- 1 pi pi 33757862 dub 3 2017 Roh_levy_V_2.gcode
-rw------- 1 pi pi 1200398 kvě 16 2017 roh_pravy.gcode
-rw------- 1 pi pi 2134740 srp 22 2016 Roh_V_2.gcode
-rw------- 1 pi pi 2139965 kvě 17 2017 rohy.gcode
-rw------- 1 pi pi 892604 pro 7 2017 roleta.gcode
-rw------- 1 pi pi 22472005 srp 17 2016 Rozperka.gcode
-rw------- 1 pi pi 32417356 čen 1 2017 rukojet_na_rucni_vkladani_v3.gcode
-rw------- 1 pi pi 8386357 čen 1 2017 rukojet_na_rucni_vkladani_v3_1_kus.gcode
-rw------- 1 pi pi 16781396 čen 2 2017 rukojet_na_rucni_vkladani_v3_2_kusy.gcode
-rw------- 1 pi pi 61647 čen 21 2017 sablona_-_senzor.gcode
-rw------- 1 pi pi 6440947 zář 12 2017 sada_1_65_ACM.gcode
-rw------- 1 pi pi 5936536 zář 12 2017 Sada_2_77_ACM.gcode
-rw------- 1 pi pi 5931706 zář 13 2017 Sada_3_77_DACH.gcode
-rw------- 1 pi pi 4093236 zář 7 2016 Sai.gcode
-rw------- 1 pi pi 4890894 čen 14 2017 SAM_65EGI_jig_ver2_RIGHT.gcode
-rw------- 1 pi pi 2830510 čec 20 2016 savka_pro_M3iA6A_KOV_v5.gcode
-rw------- 1 pi pi 7062680 srp 18 2016 savka_pro_M3iA6A_vacuum.gcode
-rw------- 1 pi pi 6251293 čec 26 2016 Sestava_ppravku_WHT250.SLDPRT_(opraveno).gcode
-rw------- 1 pi pi 4287188 čec 27 2016 Sestava_pripravku_WHT150.SLDPRT_(repaired).gcode
-rw-r--r-- 1 pi pi 768080 dub 13 2018 Sestava1fluxovacka.gcode
-rw------- 1 pi pi 224305 úno 19 2018 Signalizacni_praporek_1.gcode
-rw-r--r-- 1 pi pi 17274109 lis 1 08:45 silo.gcode
-rw-r--r-- 1 pi pi 3440980 říj 31 15:30 silo_horni_viko.gcode
-rw-r--r-- 1 pi pi 524288 říj 16 14:04 Sipka.gcode
-rw------- 1 pi pi 17471670 bře 5 2017 siroky_otvor_vlevo_25mm.gcode
-rw------- 1 pi pi 558902 srp 22 2017 slot.gcode
-rw------- 1 pi pi 58777423 dub 4 2017 Sloupek.gcode
-rw------- 1 pi pi 3850226 bře 16 2018 Snitch.gcode
-rw------- 1 pi pi 14043795 bře 16 2018 Snitch_4_.gcode
-rw-r--r-- 1 pi pi 728896 čen 21 11:53 spona.gcode
-rw-r--r-- 1 pi pi 1780473 lis 13 12:00 spona_gola.gcode
-rw------- 1 pi pi 1412754 čec 27 2017 spona_gola_V3.gcode
-rw------- 1 pi pi 2680864 říj 9 2017 SPONA_2.gcode
-rw-r--r-- 1 pi pi 1008162 čen 22 08:30 sponky.gcode
-rw-r--r-- 1 pi pi 14014105 čen 21 12:22 spony.gcode
-rw------- 1 pi pi 1279752 dub 16 2017 spunt_do_pepiny.gcode
-rw------- 1 pi pi 4511002 pro 9 2016 Squirrel_cookie_cutter.gcode
-rw------- 1 pi pi 46957758 lis 27 2017 Stinitko_(Rez_1)_(opraveno).gcode
-rw------- 1 pi pi 44794577 pro 1 2017 Stinitko_(Rez_2)_(opraveno)_Back_Extruder.gcode
-rw------- 1 pi pi 44794580 lis 27 2017 Stinitko_(Rez_2)_(opraveno).gcode
-rw------- 1 pi pi 76190585 pro 2 2017 stinitko2_tenci.gcode
-rw------- 1 pi pi 3925801 led 26 2017 stojanek.gcode
-rw-r--r-- 1 pi pi 11999027 říj 30 13:56 stopr.gcode
-rw-r--r-- 1 pi pi 588207 říj 30 07:47 stopr_jeden.gcode
-rw------- 1 pi pi 1135620 srp 22 2016 stranovy_doraz_V_2_-_1mm.gcode
-rw------- 1 pi pi 2046188 čen 27 2017 tay_giat_Simple.gcode
-rw------- 1 pi pi 3932782 bře 6 2018 Teleso_extruderu_V2_podory_prt.gcode
-rw------- 1 pi pi 2849225 bře 5 2018 Teleso_extruderu_V2_prt.gcode
-rw------- 1 pi pi 3851016 bře 5 2018 Teleso_extruderu_V2_2prt.gcode
-rw-r--r-- 1 pi pi 11403983 lis 26 12:23 telo.gcode
-rw------- 1 pi pi 3308446 dub 11 2018 teraz.gcode
-rw------- 1 pi pi 110251 srp 1 2017 Tlacitko.gcode
-rw------- 1 pi pi 1189370 zář 22 2017 Tlacitko_ultrazvuku.gcode
-rw------- 1 pi pi 112618 srp 1 2017 Tlacitko2.gcode
-rw------- 1 pi pi 118158 srp 1 2017 Tlacitko3.gcode
-rw------- 1 pi pi 4297280 pro 20 2017 Tlacny_pin.gcode
-rw------- 1 pi pi 9009892 pro 1 2017 12_uchyt_plexi.gcode
-rw------- 1 pi pi 13650658 čec 18 2017 12_zoubek_zaobleny-mala_dira_new_model.gcode
-rw------- 1 pi pi 19499858 čec 28 2016 15_-_022.gcode
-rw------- 1 pi pi 6950004 pro 19 2016 1-8_washer.gcode
-rw------- 1 pi pi 16450460 bře 27 2017 1929840_1._kus.gcode
-rw------- 1 pi pi 3778998 kvě 11 2017 2_remenice_T10_10.gcode
-rw------- 1 pi pi 27385008 led 25 2017 2_vidlicka_plunzru.gcode
-rw------- 1 pi pi 6890517 led 16 2017 2x_zadni_vedeni_Metal_bezel_siroky_30mm_(opraveno).gcode
-rw------- 1 pi pi 18787118 lis 23 2016 2016_module_line_-_kryt_-_forma.gcode
-rw------- 1 pi pi 11514926 čen 21 2017 2016_module_line_-_kryt_-_zaslepka_7_Builder.gcode
-rw-r--r-- 1 pi pi 13946736 dub 15 2018 2018_olepovani__zuby.gcode
-rw-r--r-- 1 pi pi 2514127 pro 13 12:22 2_5_to_3_5_drive.gcode
-rw------- 1 pi pi 2613862 pro 7 2017 3x_roleta.gcode
-rw-r--r-- 1 pi pi 7301536 lis 29 10:44 3_zuby.gcode
-rw------- 1 pi pi 4433846 úno 13 2018 4_Drzak_cidla_pro_pouzdro_pinu.gcode
-rw------- 1 pi pi 10122570 zář 8 2016 4.gcode
-rw------- 1 pi pi 946577 bře 29 2018 49FX700_centrovani_konektoru_luzko.gcode
-rw------- 1 pi pi 526840 bře 12 2018 49FX700_2x.gcode
-rw------- 1 pi pi 5870501 říj 4 2017 55DACH_L_R.gcode
-rw------- 1 pi pi 2954488 říj 6 2017 55DACH_R.gcode
-rw------- 1 pi pi 4575502 čec 10 2017 55DACH_R_V_2.gcode
-rw------- 1 pi pi 2820890 srp 15 2017 55EGI_jig_ver2_RIGHT.gcode
-rw------- 1 pi pi 5734426 srp 15 2017 55EGI_jig_ver2_RIGHT_LEFT_bez_podpor.gcode
-rw------- 1 pi pi 4922401 srp 11 2017 55EGI_jig_ver2_RIGHT_LEFT.gcode
-rw------- 1 pi pi 8287053 čen 30 2017 55EGI_jig_ver2_RIGHT_LEFT_2a2ks.gcode
-rw------- 1 pi pi 3079953 lis 23 2017 55EZ950_DACH_L_23_11.gcode
-rw------- 1 pi pi 12946589 zář 14 2017 55EZ950_EGI_L.gcode
-rw------- 1 pi pi 3212291 lis 23 2017 55EZ950_EGI_L_23.11.gcode
-rw------- 1 pi pi 6360278 dub 6 2018 55EZ950_--1-5_R.gcode
-rw------- 1 pi pi 3289017 dub 10 2018 55EZ950_--1-5_R_2.gcode
-rw------- 1 pi pi 1947392 dub 5 2018 55EZ950_--2-1_L.gcode
-rw------- 1 pi pi 3500952 dub 5 2018 55EZ950_--2-1_L_noc.gcode
-rw------- 1 pi pi 425205 bře 12 2018 55FX700_2krat.gcode
-rw-r--r-- 1 pi pi 1136732 kvě 22 2018 6.gcode
-rw------- 1 pi pi 2104250 čec 3 2017 65EGI_jig_ver2_LEFT.gcode
-rw------- 1 pi pi 9948380 čen 5 2017 65EGI_jig_ver2_RIGHT.gcode
-rw------- 1 pi pi 8029965 čen 30 2017 65EGI_jig_ver2_RIGHT_LEFT_2a2ks.gcode
-rw------- 1 pi pi 28053805 lis 16 2017 65EZ1000_ACM.gcode
-rw------- 1 pi pi 6182280 zář 1 2017 65EZ1000_ACM_L.gcode
-rw------- 1 pi pi 6235794 zář 19 2017 65EZ1000_ACM_L_R.gcode
-rw------- 1 pi pi 13232597 led 5 2018 65EZ1000_ACM_L_R__77EZ1000_DACH_L_R.gcode
-rw------- 1 pi pi 3115462 říj 13 2017 65EZ1000_ACM_L_-3mm.gcode
-rw------- 1 pi pi 6065798 říj 2 2017 65EZ1000_ACM_R.gcode
-rw------- 1 pi pi 5458618 zář 4 2017 65EZ1000_ACM_R_L.gcode
-rw------- 1 pi pi 2983482 říj 13 2017 65EZ1000_ACM_R_-3mm.gcode
-rw------- 1 pi pi 6675668 lis 23 2017 65EZ1000_ACM_R_32_11.gcode
-rw------- 1 pi pi 6247188 dub 9 2018 65EZ950_--2-5_R_a_L.gcode
-rw------- 1 pi pi 5630258 srp 28 2017 77EZ1000ACM_L_R.gcode
-rw------- 1 pi pi 5928035 srp 29 2017 77EZ1000ACM_R.gcode
-rw------- 1 pi pi 5941334 srp 29 2017 77EZ1000DACH_L.gcode
-rw------- 1 pi pi 5753576 srp 28 2017 77EZ1000DACH_R_L.gcode
-rw------- 1 pi pi 5930897 zář 7 2017 77EZ1000DACH_R_MP1.gcode
-rw------- 1 pi pi 2422825 srp 21 2017 77EZ1000_L.gcode
-rw------- 1 pi pi 2434906 srp 21 2017 77EZ1000_R.gcode
-rw------- 1 pi pi 3749401 srp 14 2017 77EZ1000_R_L.gcode
pi@octopiBuilder:~ $ ls -l ~/.octoprint/timelapse
celkem 317240
-rw-r--r-- 1 pi pi 40865792 čec 2 16:56 Dil_A_20180702105441.mpg
-rw-r--r-- 1 pi pi 43835392 čec 3 14:01 Dil_A_20180703080651.mpg
-rw-r--r-- 1 pi pi 41809920 čec 3 20:17 Dil_A_20180703142400.mpg
-rw-r--r-- 1 pi pi 2889728 říj 9 08:56 drzak_VSi_V_D_-_Drzak_VSi_V_D_horni_dil_20181009082447.mpg
-rw-r--r-- 1 pi pi 2883584 říj 9 09:37 drzak_VSi_V_D_-_Drzak_VSi_V_D_horni_dil_20181009090708.mpg
-rw-r--r-- 1 pi pi 5879808 čec 4 13:32 FX800_BTM_oprava_20180704123113.mpg
-rw-r--r-- 1 pi pi 6455296 říj 8 14:00 klinek_pro_technickyV2_20181008123812.mpg
-rw-r--r-- 1 pi pi 1671168 říj 8 10:43 klinek_pro_technicky_20181008102817.mpg
-rw-r--r-- 1 pi pi 649216 říj 8 10:58 klinek_pro_technicky_20181008104452.mpg
-rw-r--r-- 1 pi pi 7243776 říj 8 12:37 klinek_pro_technicky_20181008112841.mpg
-rw-r--r-- 1 pi pi 39653376 čen 27 20:31 Madlo_na_vrtacku_20180627144456.mpg
-rw-r--r-- 1 pi pi 37855232 čec 12 19:01 Owl_2_20180712122719.mpg
-rw-r--r-- 1 pi pi 56162304 čec 16 23:10 pedal_rohy_20180716124741.mpg
-rw-r--r-- 1 pi pi 2404352 čec 16 12:42 pedal_V_03.0_20180716122429.mpg
-rw-r--r-- 1 pi pi 1208320 čec 4 11:34 podlozka_izol_20180704112536.mpg
-rw-r--r-- 1 pi pi 7219200 čec 9 12:03 pouzkyvcz250_20180709104925.mpg
drwxr-xr-x 2 pi pi 4096 čec 25 2016 Scripts
-rw-r--r-- 1 pi pi 1862 čec 25 2016 scripts.zip
drwxr-xr-x 2 pi pi 2129920 pro 11 16:31 tmp
-rw-r--r-- 1 pi pi 11194368 čen 27 14:37 V1_3ks_20180627124703.mpg
-rw-r--r-- 1 pi pi 12810240 čec 5 00:49 zoubek_zaobleny-mala_dira_new_model_20180704224217.mpg
In the meantime, I'd suggest downloading and then deleting the timelapses which are over 10MB in size and then try again. There's probably a point where it will work out.
If you're handy with Linux command line, you could use some of the techniques in my own backup helper script. Read through the script and you can adapt line 35 to create a tarball of your timelapse subfolder and another one for your uploads. Then you can manually use the scp examples to pull the zip'd versions to your workstation. "Go to school" on the commands in the restore section for how to reverse this. (It's good to know enough UNIX to be able to manage things when automated things fail for whatever in cases like yours.)
Not needed, already fixed in this commit and to be rolled out in 1.3.11. Until then, if this problem is encountered I suggest to either clean up first or run backups manually for now.
