Is there any current way (short of writing a new plugin) to have a routine take different actions based on printer responses?
E.g.
- Probe this point, if it's not within certain bounds then run gcode to level bed.
- While all endstops (M119) are off, lower 0.1mm (e.g. if your printer is set to home from a probe but you still have a z-stop connected, you can use this to auto-calibrate the probe)
There must be loads of other examples where you want to run a bit of GCODE and then react to the printer's response.
I've been through scripts, snippets and action commands. The closest I can find is the terminal response plugin but that doesn't have any provision for sequencing.
I appreciate that GCODE doesn't natively support this so it would be Octoprint that's looking at the responses from the printer.
