Be able to install or apply a phyton file with octorprint installed on the raspberry
Good day. A query, is it possible to run a python (py) file on a Raspberry with octoprint installed? or must Raspian necessarily be installed on the SD card?
Assuming you are using an OctoPi image, anything you can do on Raspbian you can also to on OctoPi, since OctoPi is based on Raspbian.
