Bed Temp Won't Set
###What is the problem?
When i put a temp in for the bed on a Flashforge Creator Pro octoprint just sets it to off again and when i try to heat the left extruder it starts heating the right one instead
I took the sd card out
Yes
octoprint-systeminfo-20220827173821.zip (35.1 KB)
Im using the flashforge creator pro with the gtx plugin and im running octoprint on a linux laptop.
Have you setup OctoPrint for 2 extruders?
I have put 2 extruders in the settings.
Edit: Do I need to set the offset? And how do I set that up?
Yes, you have to setup the nozzle offsets to OctoPrint. But this for the functionality of OctoPrint.
If found this in the logs:
v
Send: M104 T1 S9
Recv: ok
Recv: // echo: (line 6) Semantic warning: T1 cannot select non-existant extruder
And according to this:
Send: M140 S9
Recv: ok
Recv: // echo: (line 8) Semantic warning: M140 cannot select non-existant heated build platform
The printer has no heated bed.
Either it is a different printer or the wrong firmware.
Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Sailfish FIRMWARE_VERSION:7.8 FIRMWARE_URL:http://www.sailfishfirmware.com MACHINE_TYPE:r2 EXTRUDER_COUNT:1
Recv: Cap:EMERGENCY_PARSER:1
