3/4 of the way through bed visualisation the printer disconnects from octopring and reports "Your printer's firmware reported an error. Due to that OctoPrint will disconnect." It also says that Probing has failed
I have tired restarting both the Octoprint and printer.
Running in safe mode doesn't allow for the pluggin to run.
Recv: T:24.18 /0.00 B:59.96 /60.00 @:0 B@:42
Recv: echo:busy: processing
Recv: Error:Probing Failed
Changing monitoring state from "Operational" to "Error"
Send: M112
Send: N2 M11235
Send: N3 M104 T0 S034
Send: N4 M140 S0*97
OctoPrint 1.9.3, Ender 3 V2, Chrome, OctoPi 1.0.0, Creality's last Bl/Cr touch firmware, Windows 10
Yeah, too much difference can also trigger probing failure. I always recommend going through manual leveling process first. You might want to check out the AutoBIM plugin for that.
