Is there a reason that bed visualiser works with creality's firmware but not with MRiscoC's firmware. With MRiscoC's frimware this is the report from the printer.
A kind advice: Please do not delete the template when you open a new Get Help thread.
Even if you already have opened a thread and attached the system info bundle.
To help properly, we always need a fresh systeminfo bundle.
It is quite tedious to fish it out of the hundreds of threads here.
So please attach the systeminfo bundle to your next post
For future refrence for anybody that is having this problem, with creality's firmware it will say "Failed to enable Bed Leveling" if you try to level the bed without already creating a mesh before starting octoprint. In MRiscoC this is shown as the printer reporting a fully level bed.
was going to mention that your report there was all 0, so probably not run. If using the example scripts documented on the repo I don't know if this would have happened to you or not, depending on which one you used.
