I have already tried. Exactly the same error.
So it does all the probing points and fails with the last?
Yes, the one in the top right corner.
I assume you have a Creality printer.
Is the printbed manually levelled as flat as possible? So that none of the corners is higher than the others?
I just screwed the pressure board all the way down. And now the same error happened at the first point.
I have now screwed all screws one turn upward. And it works again. Strange Bug. But thank you both for helping me.
Often if the bed is too far out of level when it goes to probe a point (I can't remember what the distance is off the top of the bed) then this error will be triggered.
