Bed Visualizer Probing Failed Printer killed Please Reset
I have downloaded the Bed Visualizer for my CR Touch. And when I want to update the mesh, it doesnt works. It heats up and begin leveling. But after a while I get a error: "Probing Failed" on OctoPrint and the LCD Display said: "Error; Printer Killed Please Reset. Thank you for your effort.
octoprint (2).log (114.9 KB)
I looked to see if another plugin was interfering with it. And tried other Gcode examples(BedVisualizer Github).
yes
no
2023-01-29 11:44:05,442 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2023-01-29 11:44:05,443 - octoprint.util.pip - INFO - ==> pip ok -> yes
2023-01-29 11:44:05,583 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2023-01-29 11:44:05,610 - octoprint.plugins.softwareupdate - INFO - Cleaned up -5 old update log entries
2023-01-29 11:44:05,610 - octoprint.plugins.softwareupdate - INFO - Loaded update log from disk
2023-01-29 11:44:05,720 - octoprint.plugins.firmwareupdater - INFO - Python binproto2 package installed: False
2023-01-29 11:44:05,775 - octoprint.plugin.core - INFO - Initialized 31 plugin implementation(s)
2023-01-29 11:44:05,817 - octoprint.plugin.core - INFO - 31 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
|  Bed Visualizer (1.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelvisualizer
|  Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
|  Creality Temperature (1.2.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_CrealityTemperature
|  Creality-2x-temperature-reporting-fix (0.0.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_ender3v2tempfix
|  Cura Thumbnails (1.0.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_ultimakerformatpackage
|  Dashboard (1.19.9) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_dashboard
|  Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
|  Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
|  Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
|  File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
|  Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
|  Firmware Updater (1.13.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmwareupdater
|  GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
|  Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
|  Ngrok Tunnel (0.4.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_ngrok
|  OctoApp (1.1.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octoapp
|  OctoEverywhere! (1.11.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octoeverywhere
|  Octolapse (0.4.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse
|  Pi Support Plugin (2022.6.13) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
|  PrintTimeGenius Plugin (2.3.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius
|  Slicer Thumbnails (1.0.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_prusaslicerthumbnails
|  Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
|  Telegram Notifications (1.6.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_telegram
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2023-01-29 11:44:05,851 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
|  hardware:
|    cores: 4
|    freq: 1500.0
|    ram: 3971162112
|  os:
|    bits: 32
|    platform: linux
|  plugins:
|    pi_support:
|      model: Raspberry Pi 4 Model B Rev 1.2
|      octopi_version: 0.18.0
|      octopiuptodate_build: 0.18.0-1.7.3-20220323100241
|      throttle_check_enabled: true
|      throttle_check_functional: true
|      throttle_state: '0x0'
|  python:
|    pip: 20.3.3
|    version: 3.7.3
|    virtualenv: /home/pi/oprint
2023-01-29 11:44:05,872 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2023-01-29 11:44:05,873 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2023-01-29 11:44:05,874 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-manifest.json...
2023-01-29 11:44:06,061 - octoprint.plugins.PrintTimeGenius - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-01-29 11:44:06,062 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin PrintTimeGenius is DISABLED
2023-01-29 11:44:06,066 - octoprint.plugins.bedlevelvisualizer - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-01-29 11:44:06,067 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin bedlevelvisualizer is DISABLED
2023-01-29 11:44:06,070 - octoprint.plugins.firmwareupdater - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-01-29 11:44:06,070 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin firmwareupdater is DISABLED
2023-01-29 11:44:06,075 - octoprint.plugins.octolapse - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-01-29 11:44:06,076 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin octolapse is DISABLED
2023-01-29 11:44:06,522 - octoprint.plugins.firmwareupdater - INFO - Setting maximum upload size for /flash to 5243904
2023-01-29 11:44:06,522 - octoprint.server - INFO - Shutting down intermediary server...
2023-01-29 11:44:06,573 - octoprint.server - INFO - Intermediary server shut down
2023-01-29 11:44:06,577 - octoprint.events - INFO - Processing startup event, this is our first event
2023-01-29 11:44:06,577 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2023-01-29 11:44:06,584 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2023-01-29 11:44:06,585 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2023-01-29 11:44:06,596 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2023-01-29 11:44:06,620 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyUSB0
2023-01-29 11:44:06,747 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2023-01-29 11:44:06,752 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2023-01-29 11:44:06,755 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2023-01-29 11:44:06,760 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2023-01-29 11:44:06,795 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2023-01-29 11:44:06,802 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-29 11:44:06,844 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-29 11:44:06,846 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2023-01-29 11:44:06,854 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2023-01-29 11:44:06,857 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2023-01-29 11:44:06,890 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-29 11:44:06,940 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin Creality 3D"
2023-01-29 11:44:06,950 - octoprint.plugins.firmwareupdater - INFO - Setting BINARY_FILE_TRANSFER capability to False
2023-01-29 11:44:06,959 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2023-01-29 11:44:09,801 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2023-01-29 11:44:10,635 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2023-01-29 11:44:10,648 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2023-01-29 11:44:10,725 - octoprint.plugins.octoeverywhere - INFO - OctoPrint host:127.0.0.1 port:5000
2023-01-29 11:44:10,744 - octoprint.plugins.octoeverywhere - INFO - OctoPingPong stats loaded from file.
2023-01-29 11:44:10,746 - octoprint.plugins.octoeverywhere - INFO - mDns Cache file loaded. Cached Entries Found: 0
2023-01-29 11:44:10,752 - octoprint.plugins.telegram - ERROR - Exception on_startup: 'NoneType' object has no attribute 'port'
2023-01-29 11:44:10,755 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2023-01-29 11:44:10,908 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2023-01-29 11:44:11,067 - octoprint.plugins.octoeverywhere - INFO - IPV4 - starport:142.93.161.88 main:172.67.223.103
2023-01-29 11:44:11,318 - octoprint.plugins.octoeverywhere - INFO - Failed to resolve host ipv6 name [Errno -2] Name or service not known
2023-01-29 11:44:11,489 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2023-01-29 11:44:11,496 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2023-01-29 11:44:11,516 - octoprint.util.pip - INFO - ==> pip ok -> yes
2023-01-29 11:44:11,552 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 11.4GB. That is considered sufficient for updating.
2023-01-29 11:44:11,552 - octoprint.plugins.softwareupdate - INFO - Not fetching check overlays, we are offline
2023-01-29 11:44:11,693 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2023-01-29 11:44:12,222 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2023-01-29 11:44:12,806 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2023-01-29 11:44:12,876 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2023-01-29 11:44:13,434 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:44:13,434 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:44:13,954 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.178.21
2023-01-29 11:44:14,045 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2023-01-29 11:44:15,295 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2023-01-29 11:44:15,302 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2023-01-29 11:44:15,333 - octoprint.util.pip - INFO - ==> pip ok -> yes
2023-01-29 11:44:15,558 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2023-01-29 11:44:15,588 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2023-01-29 11:44:15,589 - octoprint.plugins.dashboard - INFO - Dashboard started
2023-01-29 11:44:15,602 - octoprint.JsFrontendErrors(Dash) - INFO - Js Logger (Dash) started
2023-01-29 11:44:15,638 - octoprint.plugins.ngrok - INFO - Setting ngrok auth token & region...
2023-01-29 11:44:15,638 - octoprint.plugins.ngrok - INFO - Opening ngrok tunnel...
2023-01-29 11:44:16,774 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 13, 'printer_state': 'OPERATIONAL'}
2023-01-29 11:44:17,610 - octoprint.plugins.ngrok - INFO - ngrok tunnel: 8d3d-84-181-211-25.eu.ngrok.io
2023-01-29 11:44:17,614 - octoprint.plugins.octoapp - INFO - OctoApp started, updating config
2023-01-29 11:44:17,639 - octoprint.plugins.octoeverywhere - INFO - After startup called. Starting worker thread.
2023-01-29 11:44:17,640 - octoprint.plugins.octoeverywhere - INFO - Main thread starting
2023-01-29 11:44:17,660 - octoprint.plugins.octoeverywhere - INFO - Frontend http port detected as 80, is https? False
2023-01-29 11:44:17,717 - octoprint.plugins.octoeverywhere - INFO - Attempting to use lowest latency server: wss://fra.octoeverywhere.com/octoclientws
2023-01-29 11:44:17,717 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://fra.octoeverywhere.com/octoclientws[1]
2023-01-29 11:44:18,732 - octoprint.plugins.octoeverywhere - INFO - Connected To OctoEverywhere, server con wss://fra.octoeverywhere.com/octoclientws[1]. Starting handshake...
2023-01-29 11:44:19,358 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.8.6', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1500.0, 'ram': 3971162112, 'pi_model': 'Raspberry Pi 4 Model B Rev 1.2', 'octopi_version': '0.18.0', 'octopiuptodate_build': '0.18.0-1.7.3-20220323100241', 'plugins': 'prusaslicerthumbnails:1.0.1,ultimakerformatpackage:1.0.2,telegram:1.6.5,printtimegenius:2.3.0,ngrok:0.4.0,firmwareupdater:1.13.3,dashboard:1.19.9,crealitytemperature:1.2.4,octolapse:0.4.1,octoeverywhere:1.11.1,octoapp:1.1.0,ender3v2tempfix:0.0.4,bedlevelvisualizer:1.1.1'}
2023-01-29 11:44:19,665 - octoprint.server.util.flask - INFO - Passively logging in user pi from 127.0.0.1
2023-01-29 11:44:19,665 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:44:19,811 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://octopi.local/', 'path': '/', 'query_string': 'l10n=de'}
2023-01-29 11:44:20,164 - octoprint.plugins.octoeverywhere - INFO - Handshake complete, server con wss://fra.octoeverywhere.com/octoclientws[1], successfully connected to OctoEverywhere!
2023-01-29 11:44:35,771 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.8.6', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1500.0, 'ram': 3971162112, 'pi_model': 'Raspberry Pi 4 Model B Rev 1.2', 'octopi_version': '0.18.0', 'octopiuptodate_build': '0.18.0-1.7.3-20220323100241'}
2023-01-29 11:44:37,836 - octoprint.plugins.octoapp - INFO - OctoApp loaded config: {'maxUpdateIntervalSecs': 60, 'updatePercentModulus': 5, 'highPrecisionRangeStart': 5, 'highPrecisionRangeEnd': 5, 'sendNotificationUrl': 'https://europe-west1-octoapp-4e438.cloudfunctions.net/sendNotification'}
2023-01-29 11:44:45,808 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c920.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c920.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:45,820 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c920.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c920.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:45,836 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/raspi_cam_v2.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/raspi_cam_v2.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:45,844 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/raspi_cam_v2.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/raspi_cam_v2.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:45,870 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c250.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c250.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:45,875 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c250.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c250.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2023-01-29 11:44:52,478 - octoprint.server.preemptive_cache - INFO - ... done in 17.45s
2023-01-29 11:44:52,596 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:34.840, compression:0.105] [1407356->188395 13.386%] /
2023-01-29 11:44:52,890 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.032, compression:0.226] [1678527->438487 26.123%] /static/webassets/packed_libs.js?d41d8cd9
2023-01-29 11:44:52,906 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.010, compression:0.006] [64863->11068 17.064%] /static/webassets/packed_client.js?dd2304b0
2023-01-29 11:44:53,581 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.078, compression:0.597] [5168282->1318672 25.515%] /static/webassets/packed_plugins.js?d8bc97ee
2023-01-29 11:44:53,668 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.017, compression:0.069] [542722->126876 23.378%] /static/webassets/packed_core.js?389582e5
2023-01-29 11:44:53,701 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.011, compression:0.022] [224449->40084 17.859%] /static/webassets/packed_libs.css?b8765cc0
2023-01-29 11:44:53,728 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.010, compression:0.016] [162664->29959 18.418%] /static/webassets/packed_plugins.css?78bd50ec
2023-01-29 11:44:53,745 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.010, compression:0.007] [109799->13414 12.217%] /static/webassets/packed_core.css?512e0870
2023-01-29 11:44:53,774 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.022, compression:0.007] [78460->78491 100.040%] /static/vendor/font-awesome-5.15.1/webfonts/fa-brands-400.woff2
2023-01-29 11:44:53,800 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.019, compression:0.007] [78460->78491 100.040%] /static/vendor/font-awesome-5.15.1/webfonts/fa-brands-400.woff2
2023-01-29 11:44:53,820 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.018, compression:0.001] [13548->13559 100.081%] /static/vendor/font-awesome-5.15.1/webfonts/fa-regular-400.woff2
2023-01-29 11:44:53,835 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.014, compression:0.001] [13548->13559 100.081%] /static/vendor/font-awesome-5.15.1/webfonts/fa-regular-400.woff2
2023-01-29 11:44:53,863 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.021, compression:0.007] [80300->80263 99.954%] /static/vendor/font-awesome-5.15.1/webfonts/fa-solid-900.woff2
2023-01-29 11:44:53,884 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.014, compression:0.007] [80300->80263 99.954%] /static/vendor/font-awesome-5.15.1/webfonts/fa-solid-900.woff2
2023-01-29 11:44:53,908 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:0.020, compression:0.003] [43572->43565 99.984%] /static/vendor/font-awesome-3.2.1/fonts/fontawesome-webfont.woff
2023-01-29 11:44:53,908 - octoprint.plugins.octoeverywhere - INFO - Slipstream took 36.25759196281433 to fully update the cache
2023-01-29 11:45:24,505 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:45:24,505 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:45:24,638 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.21
2023-01-29 11:45:29,086 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2023-01-29 11:45:29,230 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:45:29,231 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:45:34,157 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.178.21
2023-01-29 11:45:34,696 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Opera', 'browser_version': '94.0.0.0', 'os_name': 'Windows', 'os_version': '10'}
2023-01-29 11:46:24,845 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:46:24,845 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:46:25,025 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.21
2023-01-29 11:46:27,324 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2023-01-29 11:46:27,394 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:46:27,394 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:46:31,450 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.178.21
2023-01-29 11:46:32,048 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Opera', 'browser_version': '94.0.0.0', 'os_name': 'Windows', 'os_version': '10'}
2023-01-29 11:46:47,831 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:46:47,831 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:46:47,960 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.21
2023-01-29 11:46:49,971 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2023-01-29 11:46:50,023 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.21
2023-01-29 11:46:50,024 - octoprint.access.users - INFO - Logged in user: pi
2023-01-29 11:46:53,117 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.178.21
2023-01-29 11:46:53,648 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Opera', 'browser_version': '94.0.0.0', 'os_name': 'Windows', 'os_version': '10'}
2023-01-29 11:47:42,600 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2023-01-29 11:52:04,883 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Probing Failed
| Last lines in terminal:
| Recv: echo:busy: processing
| Recv:   TT::19.3719.37  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::6464
| Recv:
| Recv: Error:Probing Failed
2023-01-29 11:52:04,884 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Error"
2023-01-29 11:52:04,888 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2023-01-29 11:52:04,951 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2023-01-29 11:52:04,983 - octoprint.plugins.octoeverywhere - INFO - Found hostname 127.0.0.1 in url http://127.0.0.1:8080/?action=snapshot
2023-01-29 11:52:04,983 - octoprint.plugins.octoeverywhere - INFO - No local domain found in http://127.0.0.1:8080/?action=snapshot
2023-01-29 11:52:05,317 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_firmware, payload: {'commerror_text': 'Probing Failed'}
2023-01-29 11:52:06,856 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2023-01-29 11:52:07,758 - octoprint.plugins.octoeverywhere - INFO - NotificationsHandler successfully sent 'error'```
### Additional information about your setup
<small>hardware:
|    cores: 4
|    freq: 1500.0
|    ram: 3971162112
|  os:
|    bits: 32
|    platform: linux
|  plugins:
|    pi_support:
|  python:
|    pip: 20.3.3
|    version: 3.7.3
|    virtualenv: /home/pi/oprint</small>
This error is produced by the printer.
You may check the printer.
Does the bed mesh procedure run when you start it from the printer's menu?
BTW: You posted the octoprint.log twice, but not the systeminfo bundle.
Thank you for you fast reply,
When I use the LCD Display to level the Bed it works perfectly fine.
And here is the System Bundle,
octoprint-systeminfo-20230130131214.zip (32.3 KB).
I assume you have a Creality printer.
Try with/without SD card in the printer's SD card slot.
Also try this:
Yes, I have an Ender 3.
I have the tape on the USB. And I have tried it without and with a micro-SD Card.
It is still the same as before.
You may have a look on this thread:
Yes, this is the same problem I have.
But they are talking about an Ender v2 and I only have an Ender 3.
Can I still load the file into my Ender 3?
With best regards
It more than likely is a travel distance issue or not being homed first. Which of the gcode examples are you using in the plugin's settings? I would recommend simplifying them down to the bare essentials of what you need (remove all M300 and M117 lines and only keep heating lines, homing, and @BEDLEVELVISUALIZER followed immediately by the G29 line).
Sorry for the late reply. I was busy, had a lot of things going on.
I used the Billinear Bed Leveling.
So should I take this gcode?
M140 S60 ; starting by heating the bed for nominal mesh accuracy
G28      ; home all axes
M420 S0  ; Turning off bed leveling while probing, if firmware is set
         ; to restore after G28
M190 S60 ; waiting until the bed is fully warmed up
M155 S30 ; reduce temperature reporting rate to reduce output pollution
@BEDLEVELVISUALIZER	; tell the plugin to watch for reported mesh
G29 T	   ; run bilinear probing
M155 S3  ; reset temperature reporting
M140 S0 ; cooling down the bed
M500 ; store mesh in EEPROM
yes, try those commands from the terminal tab one line at a time and see which one kills the printer.
Okay,
I have sent M155 S30 and this error came:
Send: M155 S30
Recv:   TT::19.9219.92  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::5858
Recv:
Recv: ok
No response from printer after 3 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Operational" to "Offline after error"
And Octoprint said: "There was an error communicating with the printer. Please consult the terminal output and
octoprint (3).log (84.6 KB)
for details. Error: Too many consecutive timeouts, printer still connected and alive?"
Octoprint has never said that before. But the LCD Display has no Error.
I have now sent G29 T and then the error happened, which was also the error before.
Send: G29 T
Recv:   TT::20.6620.66  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::5252
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::4747
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0260.02  //60.0060.00  @@::00  BB@@::4141
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::4343
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4646
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::4141
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0260.02  //60.0060.00  @@::00  BB@@::3737
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4444
Recv:
Recv:   TT::20.6620.66  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::3939
Recv:
Recv:   TT::20.6620.66  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::3838
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4242
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4141
Recv:
Recv:
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::4545
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9659.96  //60.0060.00  @@::00  BB@@::5555
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::4848
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::5050
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4747
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::5252
Recv:
Recv:   TT::20.6620.66  //0.000.00  BB::60.0760.07  //60.0060.00  @@::00  BB@@::2424
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::60.0260.02  //60.0060.00  @@::00  BB@@::3838
Recv:
Recv:   TT::20.5920.59  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::4242
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::3636
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3939
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3838
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::4242
Recv:
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9359.93  //60.0060.00  @@::00  BB@@::6262
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9659.96  //60.0060.00  @@::00  BB@@::5757
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9659.96  //60.0060.00  @@::00  BB@@::6161
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::5454
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::5757
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::5555
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::6161
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::5858
Recv:
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::59.9959.99  //60.0060.00  @@::00  BB@@::6363
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::5959
Recv:
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0560.05  //60.0060.00  @@::00  BB@@::4242
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.1360.13  //60.0060.00  @@::00  BB@@::1111
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0360.03  //60.0060.00  @@::00  BB@@::3636
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::4040
Recv:
Recv:   TT::20.6220.62  //0.000.00  BB::60.0260.02  //60.0060.00  @@::00  BB@@::3434
Recv:
Recv:   TT::20.7020.70  //0.000.00  BB::60.0360.03  //60.0060.00  @@::00  BB@@::2828
Recv:
Recv:   TT::20.7420.74  //0.000.00  BB::60.0260.02  //60.0060.00  @@::00  BB@@::3030
Recv:
Recv:   TT::20.7020.70  //0.000.00  BB::60.0160.01  //60.0060.00  @@::00  BB@@::3333
Recv:
Recv:   TT::20.6620.66  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3636
Recv:
Recv:   TT::20.7420.74  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3535
Recv:
Recv:   TT::20.8620.86  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3535
Recv:
Recv:   TT::20.7820.78  //0.000.00  BB::60.0060.00  //60.0060.00  @@::00  BB@@::3535
Recv:
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M140 S0*97
This was at the End of the Probing. Does this have anything to do with the printer?
Sorry, the what? :wink:
The display on the printer :dotted_line_face:
But you know what LCD stands for?
Liquid Crystal Display. But I still need help with my printers.
A reason for a failed probing can be an obstacle in the way of the probe.
No, that isn't the problem. And the bed is new.
ok, that means your firmware probably doesn't support the command. remove those M155 lines from the gcode.
try the G29 line without the T
