Freezing of Octoprint when not in safety mode - happens while printing but also when idle
checked the logs, checked if there is any throttling or under voltage or over temperature
yes
yes
octoprint-systeminfo-20220615150714.zip (371.2 KB)
Hi folks,
I have been working with Octoprint for more than two years now and print almost daily.
Recently I have again the problem that Octoprint freezes regularly. This happens both during printing and when idle. I already had this problem once a few months ago and I could fix it then only by after a complete reinstallation of Octoprint (without importing a backup). Then everything ran without problems for a long time.
After I gave my Ender 3 a firmware update last week, the same problem occurs again. However, I strongly doubt that the update is the trigger.
I have tried several adaptations, to baud rate, buffer size, in firmware and in Octoprint settings etc. and have watched the Serial.log and Octoprint.log. However, I simply cannot assign the cause.
Since everything works fine in security mode, it must obviously be one of the installed plugins. I have already rummaged through the various logs - but could not find anything so far.
What would be the best approach to get to the cause of the error?
In the attached system info bundle, I manually disconnected and reconnected the USB cable at 2022-06-15 07:41:02. At 08:15:47 I then started a print. At 08:28:09 Octoprint froze ... printing stopped. Only a complete restart of the Octoprint service helped.
Any ideas?
Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 21.3.1
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.last_safe_mode.date: 2022-06-15T11:11:11Z
octoprint.version: 1.8.1
printer.firmware: Marlin 2.0.9.3 (Jun 14 2022 08:42:44)
printer: Ender 3 Pro
