Hi I am trying to install octoprint on to a bigtreetech pi 1.2 .I have tried it by using good old YouTube videos and not been able to get it up and running.I have also been on the bigtreetech Gitt nub pages with no success..Has anyone had success in getting a bigtreetech pi running with octoprint that can point me in the right direction to get it up and running. That’s
Try to flash armbian with this image
(use the Armbian Bookworm CLI variant)
It's not quite your board, but similar enough and it might just work.
If it works install OctoPrint with this script:
(select Debian when asked which linux distro you're using)
Thanks for that info I will give it a go shortly thanks again
Did this solution work?
If you have the same issue, you may try yourself ![]()
Just try it.
The worst that can happen is that you wasted half an hour ![]()
Hi biffer,
I'm nearly 3 months late, but here's a how-to:
Get the *.pdf
I'm running OctoPrint on a BTT PI 1.2, and it runs well.
Enjoy!
Visitor.
