BLTouch and Print problems since upgrading to 1.8.6
Since I upgraded my Octoprint from an older version which I don't recall but was working perfectly fine to 1.8.6 I been having problems with prints and BLtouch going nuts. I do an update mesh the BLtouch starts probing then starts blinking and then starts making the Z access move up. If I reboot the printer, the BLtouch starts blinking and won't respond. I have started prints which the bed leveling probe starts then does the blinking and the z axis starts to climb and does not probe. I had a few prints that started and after the probing and well into the print the BLtouch starts blinking and Z axis starts to incrementally start to rise. It takes a full power down and disconnect the USB port and reboot of Octoprint to start working again. I run it on repetier host and it works fine once I get the BLtouch fully reset after a power cycle. I did the Octopi upgrade from the CLI that did the upgrade for an older version that was still running python 2.x
I check the wiring, reset the printer, run self test on the BLtouch
no, problems prior to upgrading Octoprint.
Tevo Tarantula MKS Base 1.4, Marlin EZ config from January, 2018,
octoprint-systeminfo-20230111103847.zip (37.9 KB)
Please do anyway.
No problems prior to upgrade. I don't recall the previous version but it was several years old.
