If I try to print some that I have transfer via CURA to the OctoPI (running last OctoPrint and OctoDash) and while the printer heating up, most the Board makes a reset (last Marlin).
So then Octo* goes to sleep. If I touch and wake him up (again), the board right now while Octo* wake up makes the next reset most of the time.
So if I'm sometimes able to have all running and try to print some, the board makes the next reset if the heater goes on (after ~2 seconds)
I have checked the PSU (12V30A) and also the board 5v0 and 3v3 and the PI's voltages with a Storage oscilloscope. The power sources are without any drops or anything else, stable and clean.
I also have delete all the startcode in CURA and sliced it again; same as before.
I have placed a 47000µF LowESR direct on the board power clamps to be shure... No change
Assuming you have installed OctoPi on a Raspberry Pi
That does not happen with OctoPi. Or you shutdown the system from the OctoPrint web GUI.
A lot of printer boards perform a reset when a USB connection is established.
BTW: Its a bit confusing. Obviously you call your Raspberry Pi with OctoPi/OctoPrint on it OctoPi. We actually use the term/name OctoPi only for the software bundle of OS and OctoPrint.
Ok, I didn't know that. Thanks for the clarification.
And yes, I used the name OctoPI for the RaspBerry and OS as well as OctoPrint and OctoDash. That somehow made sense to me. But now it's clear.
No, yes, similar. ^^
So when I shut down the RaspBerry (i.e. the OS with OctoPrint and OctoDash) using the TouchDisplay installed on it, the board resets.
The same thing happens when the RaspBerry is “asleep” because there are no jobs or because the board has previously reset. If I then tap the touch display to wake it up, OctoPrint tries to connect to the printer again (which sometimes leads to a 409 conflict), and the board resets again.
If it worked once without a reset, I select the previously transferred file for printing on the RaspBerry display and say "print this now", then the board resets again as soon as the heaters are started up.
At the moment it is only possible to finish a job or even start it with a lot of patience and luck.
The fact that the board resets with a USB connection would explain the reset at startup and the first connection attempt or during a wake-up call. But when starting a job?
Could it be that the USB connection wobbles from time to time and OctoPrint re-establishes it in the background without noticing it?
