Booting into emergency mode and then hanging
OctoPrint boots into emergency mode every time I do a fresh installation. Once it says generating ssh keys it says "Failed to write wtmp record, ignoring: Read-only file system." It then says it is going to reboot but never does, so I cut the power and restore. After a little while, it says
 [ TIME ] Timed out waiting for device dev-disk-by\x2duuid-C829\x2dC4C1.device.
 [DEPEND] Dependency failed for file system check on /dev/disk/by-uuid/C829-C4C1.
 [DEPEND] Dependency failed for /boot/efi.
 [DEPEND] Dependency failed for Local File System.
it says press enter to continue, and after I do it hangs, with the carat being frozen solid.
I tried multiple different SD cards and many fresh installations, but they all have the same result.
It is impossible to run it in safe mode because I cannot execute any commands.
N/A
Does your Pi boot into non-OctoPi images? Is it brand new or has it worked before?
It has worked before. I have had it for 2+ years, with it bouncing around projects. I actually got it to work with octopi, but after a couple of successful boots, this started happening, so I reburned the image multiple times, all to no avail.
Resolved: used SD Memory Card Formatter for Windows/Mac | SD Association (sdcard.org) to reformat.
