Both Octoprint servers/printers suddenly not running with no visible problems
I was at vacation for 2 weeks, and after getting back home I've found that BOTH of my printers are suddenly refuse to run the Web Service. The versions are 1.8.6 and 1.8.7. (I've got also older 1.7.x server on the 3rd printer, and that one still works fine)
Going to WEB interface of the printers I get standard OctoPI message: "The OctoPrint server is currently not running". So the server is working but due to some problem it is not launching the Octopi Interface.
Checked the free space - everything is fine.
Checked the log file - nothing critical so far: (UPDATE: actually it is way too short comparing to the older successful runs)
2023-08-08 10:07:20,717 - octoprint.startup - INFO - ******************************************************************************
2023-08-08 10:07:20,733 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2023-08-08 10:07:20,737 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2023-08-08 10:07:20,738 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2023-08-08 10:07:20,738 - octoprint.startup - INFO - ******************************************************************************
2023-08-08 10:07:23,285 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2023-08-08 10:07:23,412 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2023-08-08 10:07:23,413 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2023-08-08 10:07:23,413 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
Tried running in Safe Mode - no changes.
Can't access the dialog..
All printers connected to LAN through ASUS RC-AC66U, and I can SSH all of them. Octoprint ran from Raspberry PI 2.
Connecting from Android phone, and from Win10 PC.
The launch command does not look 100% exact to Octopring suggested. Suggested:
python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
actual
/usr/bin/python3 /home/pi/.local/bin/octoprint
P.S. By analysing the old logs it looks like I've installed some updates to the both printers before going to Vacation. Current and previous logs attached
octoprint.log (3.7 KB)
octoprint.2023-07-20.log (134.8 KB)
Try it via ssh :slight_smile:
Generate it with
~/oprint/bin/octoprint systeminfo .
and download it with WinSCP
Interesting... When I run this command it just does nothing and HANGS. I now suppose Octoprint also hangs when ran as service...
But how do I debug it?
My command is bit different due to path - ~/.local/bin/octoprint systeminfo
P.S. Tried verbose - ~/.local/bin/octoprint -v systeminfo . Silence. Nothing.
P.P.S. Ran this command on the other working printer, and it does something for 1-2 minutes, but there's no result.... Where should I search for result?
the dot at the end is missing. it's systeminfo .
It should create a zip file in the current path
Thanks for your help! It did not create any file even with dot on the end. On the other printer as well, for some reason.
I gave up and reinstalled OS. (that took 20 mins in comparison with the whole day I spent trying to repair the old one...
Weird. I would at least expect some kind of error message if something is wrong.
But who knows what happened.
Glad you found a solution :slight_smile:
Happy printing :tentacle:
