I can login octopi from another machine via IP address however Octopi fails the connectivity check. I also cannot update or turn on VNC so I can access the headless pi.
Newest version of the octopi image is running.
Hi roonton
perhaps you must activate only vnc
log on over SSH. Mac =terminal, win = Putty
ssh pi@ip-adress
Password default=raspberrypi
next:
sudo apt-get update
sudo apt-get install realvnc-vnc-server realvnc-vnc-viewer
and
sudo raspi-config
enable vnc service
and sudo reboot.
It sounds like you can connect to your OctoPrint instance but only with the IP address and not using http://octopi.local
. This to me sounds like a simple name resolution problem.
VNC is normally awesome but it requires the GUI/Desktop/X-Windows version of Raspbian Stretch PIXEL to be loaded. OctoPi uses the console-only Raspbian Stretch Lite version, so no X-Windows. VNC doesn't have anything to connect to.
If you wanted to do some work, you could run the ~/scripts/install-desktop
script. You would then have the entire Desktop and could—if you put the work into it—use VNC to get to that. In some cases, you next need to adjust the authentication of VNC on the server and to set a password.
In my post I stated I can't do any updates. Can't connect to the internet. Can ping the Pi and locally connect to the pi via browser, ssh.
[quote="OutsourcedGuru, post:3, topic:3217"]
Stated in my question that I have no connectivity to the internet. Accessing pi via a Mac.
sound like
the Raspi has no connection to router.
Then log on over ssh
run
sudo raspi-config
check Network settings
Network and Password.
or run
sudo nano /etc/dhcpcd.conf
and chek this also.
What we know:
sudo apt-get update
, for exampleWhat we don't know:
ifconfig
The output of ifconfig
might indicate whether or not the Raspberry Pi has been given some default DNS servers for looking up hostnames. If not, it would behave like his. Likewise and as suggested, it could also be that the Raspberry Pi doesn't have the proper default route to your router. Also, the netmask (as given during the DHCP phase) could be wrong.
