Camera modelLogitech C270
**What is the problem?**Get the still picture but the stream does not work. Webbrowser stream also does not work out using URL http://192.168.178.50:8080/ Web browser displays: 501: Not Implemented!
no www-folder configured
**What did you already try to solve it?**created an octopi.txt although that may not work when otpprint was installed in raspbian, right? and specified resolution and frame rate, multiple reboot.
the mjpg streamer launches but denotes that frame rate is "-1". Found no way to alter that since I assume that is the issue. Installed Raspian Buster - fresh load and followed the detailed installation instruction Setting up OctoPrint on a Raspberry Pi running Raspbian
Tried to set camera options following Available mjpg-streamer configuration options
compiling mjpg-streamer works just fine, no compilation errors, launching gives the following:
pi@raspberrypiVerteilung1:~/mjpg-streamer/mjpg-streamer-experimental $ ./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
i: Frames Per Second.: -1
i: Format............: JPEG
o: www-folder-path......: disabled
o: HTTP Listen Address..: (null)
o: commands.............: enabled
Checked related topics in the forum w/o finding a reasonable match or solution.
/var/log/webcamd.log is empty
Additional information about your setup (OctoPrint version, OctoPi version, ...)octoprint.log (176.0 KB) plugin_pluginmanager_console.log (97.1 KB)
