C270 & Octoprint - Prusa MK3 - The webcam server is currently not running
Logitech C270
I can't access the webcam nor starting the webcam server
Edit octopi.txt with different resolutions and frame rate, with or with "-f", "-y", ecc.
Logs
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1280x960 -f 30
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Dec 2 12:56:19 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1280x960 -f 30 -d /dev/video10
Goodbye...
i: Using V4L2 device.: /dev/video10
i: Desired Resolution: 1280 x 960
i: Frames Per Second.: 30
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
OctoPrint version : 1.7.3
OctoPi version : 0.18.0
static ip address: 192.168.1.200
Please community help me!
Tnks
It doesn't look like it's seeing the camera as a video device.
SSH to the Pi and run lsusb and see if it is listed, first
Hi Charlie_Powell
this is what came up from lsusb command:
Please note that:
  • the webcam is attached solely to the raspberry pi via micro-usb
  • there are no other power source to the cam
  • the Raspberry Pi Zero 2 W is connected to the Prusa MK3 via solded pins
  • the cam is working just fine when connected to my notebook
  • between the raspberry and the webcam I attached an adapter USB Micro B male to USB A female
Can I do anything differently?
Thank you again for the help.
Just to make sure, you actually attached the cam to the USB data port, not the USB power in port?
You nailed it. As simple as that!
Tomorrow I’ll switch the port and report the follow up.
Thanks to all.
Ciao
Hi Foosel, you were totally right.
I was mistaken with the USB port.
Thank you again. :wink:
