I Need to call an http on events start and done
I have searched inside all plugin, none seems to do what i need
Many thanks for your help, is there a modification i can make to do this ?
Here are the two events you're interested in. As described above this in the configuration section...
events:
enabled: True
subscriptions:
- event: PrintStarted
command: ~/scripts/print-started {file}
type: system
- event: PrintDone
command: ~/scripts/print-done {file}
type: system
#!/bin/sh
curl http://someserver.com/api/print-started/$1
...and don't forget to chmod the script(s) so that they're executable.
That example script is a shell script, not a python script, but you are opening it with python.
Ah, yes. (More coffee.) I edited it slightly above.
Thanks or your help !
I create a files ( print-started + print-started.sh , and print-done & print-done.sh )
When i start my print, no notification sent
When i test in cmd print-started, i works
i add a conf in config.yaml
Thanks for your help
I think I would recommend /home/pi/scripts/print-started as the path rather than the one with the tilde. You want to do an ls -l ~/scripts to confirm that the two files you've created have the executable flag in them.
Hello,
I am quite new in OctoPrint and not an Linux expert.
I would like to as end an URL request after the printing progress ended at 100% AND the rendering of time-laps were done.
I would like to use my FHEM home-automation for turning off the plug, where the printer is connected to. I can turn off the printer by requesting this url from my Windows PC:
I configured OctoPrint via GUI:
Eventmanager > Event "MovieDone" added (Command with curl {url]) / Type=system
but it still doesn't seem to work. Anything I missed?
But this isnβt working. Any hint about what to do?
