As title: webcam no longer works and the Telegram plugin can't send me correct messages. Here's a part of the log I found:
2019-05-16 01:04:56,896 - octoprint.server.api - ERROR - Error calling SimpleApiPlugin telegram
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/__init__.py", line 68, in pluginData
response = api_plugin.on_api_get(request)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_telegram/__init__.py", line 858, in on_api_get
'bind_cmd':[k for k, v in self.tcmd.commandDict.iteritems() if 'bind_none' not in v ],
AttributeError: 'NoneType' object has no attribute 'commandDict'
Reinstalled with:
33 sudo service octoprint stop
34 source ~/oprint/bin/activate
35 pip install --force-reinstall https://get.octoprint.org/latest
36 octoprint serve --safe
And same problem persists. Tried moving the Webcam USB connection to other ports and still nothing.
(oprint) pi@octopi2:~/.octoprint/logs $ ~/oprint/bin/octoprint --version
octoprint, version 1.3.11
(oprint) pi@octopi2:~/.octoprint/logs $ cat /etc/octopi_version
0.15.1
Printer is CR10 S5 and firmware is Merlin
Some info of my console:
Here's the webcam log:
Starting up webcamDaemon...
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
http options: -w ./www-octopi -n
Found video devices:
/dev/video0
USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>May 15 12:54:28 pi: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: (null)
Goodbye...
And
(oprint) pi@octopi2:~/.octoprint/logs $ lsusb
Bus 001 Device 008: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 010: ID 046d:085e Logitech, Inc.
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
And complete log file:
https://cl.ly/0e24d276d991/download/octoprint.log
