Camera Module V3 - Device or resource busy
Raspberry Pi Camera Module V3
Can't get any video feed
Updated rasp pi and followed some steps on various forums, but still not working
CLI:
jjnether@octopi:~ $ libcamera-hello
Preview window unavailable
[0:07:04.345966740] [2829]  INFO Camera camera_manager.cpp:299 libcamera v0.0.4+22-923f5d70
[0:07:04.511329074] [2830]  INFO RPI raspberrypi.cpp:1476 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media2 and ISP device /dev/media0
[0:07:04.512361515] [2829]  INFO Camera camera.cpp:1028 configuring streams: (0) 2304x1296-YUV420
[0:07:04.512815211] [2830] ERROR V4L2 v4l2_videodevice.cpp:1047 /dev/video0[13:cap]: Unable to set format: Device or resource busy
ERROR: *** failed to configure streams ***
Logs
OctoPrint version : 1.9.0
OctoPi version : 1.0.0
Any help would be greatly appreciated!
Hi :tentacle:
Are you using the image with the new camera stack?
When I installed the image with the raspPi imager, I believe I just selected the stable OctoPi version that was listed. Should I try something else?
there should be a second version with the new camera stack :slight_smile:
try this one :tentacle:
Bildschirmfoto vom 2023-05-30 17-22-02
Ahh great, when I'm back home I'll try this, thanks! Can I backup my octoPrint setup and restore with this image? And ideally should it work out of the box, or are there more settings I'll need to tweak?
Thanks again!
Backup and cam should ideally work out of the box :slight_smile:
What does "there should be a second version" mean? Second version of what? Also, what does "new camera stack" mean? Thanks!
Hello @nerdmeeting !
You read the whole thread?
@PrintedWeezl meant this:
grafik
