Raspberry Pi Camera Module 2
I got a RPi Zero 2 W the other day and I flashed the latest stable release of OctoPi onto it via a MicroSD card and the Raspberry Pi Imager. I then set everything up as detailed in the quickstart guide. I managed to get everything working, and I added the OctoEverywhere plugin so I can monitor my prints while I'm out of the house. Everything was working perfectly. Today, I got home and I booted the pi so I could test where I wanted to put the camera, as I wanted to get the best angle and then measure up so I could create a mount for it to attach to the printer. I should also probably note that I have been using the case and as some other people have mentioned, the camera slot is a tight fit. Anyway, I booted the pi this afternoon and logged into octopi.local. I went to the control tab and the space where the stream is normally located just says 'Webcam stream not loaded. It might not be configured correctly or require authentication. You can change the URL of the stream under "Settings" > "Classic Webcam" > "Stream URL". If you don't have a webcam you can also just disable webcam support there.'
Please can someone run me through what to do as if I'm 7? I really have no idea what to do.
P.S. I've looked at other people's posts and the issues seem to be caused by updating the OS, but I haven't done that since I last got the camera working.
I re-flashed the OS, but as it was a new system, I didn't have a backup to restore from. Same build and version. I have also thoroughly inspected the ribbon cable for any damage and there appears to be none whatsoever. The end that plugs into the pi itself has a bend in it from the case but it's not major and certainly wouldn't be enough to cause any issues. I have also unplugged and re-plugged the cable so many times to each device in case the position of the cable was an issue (pi turned off of course). But nothing.
Yes.
Nope
octoprint-systeminfo-20250109172612.zip (17.5 KB)
OctoPrint version - 1.10.3, OctoPi version - 1.0.0, Build 2024.11.05.100055 with "camera-streamer"
