pi@raspoctopi:~ $ lsusb ...
Bus 001 Device 004: ID 0c45:636d Microdia USB 2.0 Camera
pi@raspoctopi:~ $ ls /dev/v4l/by-path
platform-bcm2835-codec-video-index0 platform-bcm2835-isp-video-index3
platform-bcm2835-isp-video-index0 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-video-index0
platform-bcm2835-isp-video-index1 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-video-index1
platform-bcm2835-isp-video-index2 platform-feb10000.codec-video-index0
PREVIOUS OctoPI Version it was as result of ls /dev/v4l/by-path:
lrwxrwxrwx 1 root root 12 Dec 2 2020 usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-video-index0 -> ../../video0
lrwxrwxrwx 1 root root 12 Dec 2 2020 usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-video-index1 -> ../../video1
OctoPrint version : 1.10.3
OctoPi version : 1.0.0
Initially - years ago - I wanted to run multiple cameras with octoprint on octopi.
As nothing worked as expected ( under OctoPi << 1.0 ) I condensed my expectation down to ONE Cam.
BUT i only got it working once ... gave up.
Now I reflashed to newest Version and wanted to start over agin. HERE IS WHAT HAPPENED:
- absolut fresh image ... camera works.
- Reboot PI ... camera works.
- Power off / Power on PI ... camera does not work anymore and other then after the reflash again .. I cannot reanimate.
This now is on PI OS is WITH the NEW CAMERA STACK.
The nice command "libcamera-hello --list-cameras" says kind of "no cameras found" right AFTER reflashing, where Octorprint does show the stream
ALSO:
freshly flashed, cam works
Install ONE "System" Plugin on Software Update Version: ==> File Check Plugin
===> camera stream disappears. not to reanimate.
As I am not good or I am totally weak on Linux, this totally confuses me.
Read threads, reflash etc.
No more Ideas - pls see above
haven't as my intuition says: is is a virgin system and as I believe I understand a cam that in principle is supported - so what shall a safe mode chenge on a virgin system
see above
octoprint-systeminfo-20241223095906.zip (28.4 KB)
