Camera (OV5647) does not work on RPI 4b on RPI 4B
'innomaker Raspberry Pi Camera Module 5MP 1080P OV5647'
Here is the link: innomaker Raspberry Pi Camera Module 5MP 1080P OV5647 Sensor with M12 FOV90 IR Filter LEN for Raspberry Pi 4, Pi 3 B+, Pi 3, Pi 2, Pi B+, Pi A, Pi Zero: Amazon.de: Computer & Zubehör
Unfortunately there is no video stream. After connecting the camera it still worked, but only with 480p resolution. All tips that allowed me to modify the 'octopi.txt' (e.g. camera_raspi_options="-x 1920 -y 1080 -fps 30") did not work because there was no such commented out entry. After I removed all adjustments from the file, nothing worked anymore. Unfortunately I can't solve it.
Here is some more information:
  • OctoPrint version '1.10.3'
  • OctoPi 'Build 2024.11.05.092907 with "webcamd", based on OctoPi 1.0.0, running on Raspberry Pi 4 Model B Rev 1.5'
  • last entry in webcamd.log:
    'Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video10
<13>Nov 14 18:32:37 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
    MJPG Streamer Version.: 2.0
    i: Using V4L2 device.: /dev/video10
    i: Frames Per Second.: 10
    i: Format............: JPEG
    Error opening device /dev/video10: video capture not supported.
    i: init_VideoIn failed
    Done bringing up all configured video devices
    Scanning again in two minutes
    /dev/video0
    /dev/video10
    /dev/video11
    /dev/video12
    /dev/video13
    /dev/video14
    /dev/video15
    /dev/video16
    /dev/video18
    /dev/video19
    /dev/video20
    /dev/video21
    /dev/video22
    /dev/video23
    /dev/video31
    config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
    <13>Nov 14 18:34:50 root: Starting USB webcam
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
    i: Could not obtain the requested pixelformat: MJPG , driver gave us: YUYV
    ... will try to handle this by checking against supported formats.
    ... Falling back to YUV mode (consider using -yuv option). Note that this requires much more CPU power
    Unable to query that the FPS change is supported
    : Inappropriate ioctl for device
    o: HTTP Listen Address..: 127.0.0.1
    libv4l2: error turning on stream: Invalid argument
    Unable to start capture: Invalid argument
    i: Can't enable video in first time
    i: cleaning up resources allocated by input thread
Goodbye...'
Can someone help me with this?
Reimage octoprint on a blank SD card, using the version with the new camera stack.
