Camera problem under Windows
WRITE HERE Creative Live! VF0880
WRITE HERE When OctoPrint connects to the camera, either on the Classic Webcam config page or in the Control tab, it locks up.
WRITE HERE Tried different resolutions, quality and IP settings
WRITE HERE No... not sure how, or if this would help diagnose
WRITE HERE N/A
octoprint-systeminfo-20250202235306.zip (14.3 KB)
Octoprint v1.10.3 on FireFox is installed on a Core I5 3.33 GHz computer with 12 GB RAM running Win10 64 bits. I installed YawCam and it sees the camera well. Printer is an Ender 3 S1 connected via USB (Although it is not participating in this issue.)
YawCam settings are:
HTTP enabled
Stream Enabled
Settings tab:
Public IP disabled
HTTP Port: 8888
Stream port: 8082 MJPEG 800x600
Additional settings:
Max conn: 3
Show notification when viewer connects: Enabled
Frame rate: 18 FPS
Startup: HTTP & Stream
Octoprint settings
Classic Webcam:
Stream: HTTP://10.0.0.157:8081/video.mjpg
(Also tried 127.0.0.1.... - it works on another computer/printer)
If I launch YawCam and open OctoPrint, when I switch to the Control tab, the camera pane is black with a note 'Webcam stream loading'. I get a notification from YawCam that something has connected to it, and if I check the YawCam connections list, the connection is listed. After a period of time the OctoPrint tab crashes.
I also have another printer connected to a different Win10 computer running OctoPrint, with an older webcam connected using YawCam and it works fine. I can view it across the network and take timelapses.
