Camera settings lost when pi turned off
<! Bill Bachmann- ~~~~~ Filling this out properly makes it WAY more likely to get help quickly ~~~~~ -->
Camera model ribbon cable camera
What is the problem? pic upside down when pi turned off. I hit save but settings not saved
What did you already try to solve it? Removed some plugins I'm not using
octoprint-systeminfo-20211225210323.zip (21.0 KB)
Where did you hit save?
You can also use -hf or -vf in the octopi.txt
Check this guide
