I turned off the Pi while away for a week. When I came back the camera was no longer working.
Dorhea Camera Module Automatic IR-Cut Switching Day/Night Vision Video Module Adjustable Focus 5MP OV5647 Sensor 1080p HD Webcam
While webcamd seems to load fine (on port 8080) based on the log, the stream isn't available. I get a "connection refused" error when I attempt to connect to port 8080.
I've tried turning on and off the interface in raspi-config as well as many reboots. Sometimes I get a different error in the logs that looks like something else is using the camera but I can't see anything that is.
This is the last two boots from the webcamd you can see the two different results. Neither one was working.
cfg_file: /boot/octopi.txt
camera: raspi
usb options: -r 1024x768 -f 25
raspi options: -x 1920 -y 1080 -fps 25 -quality 100 -p 8181
http options: -w ./www
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':Start MJPG-streamer with video device: raspi
<13>Dec 4 09:40:00 root: Starting Raspberry Pi camera
Running ./mjpg_streamer -o output_http.so -w ./www -i input_raspicam.so -x 1920 -y 1080 -fps 25 -quality 100 -p 8181
i: fps.............: 25
i: resolution........: 1920 x 1080
i: camera parameters..............:
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
o: www-folder-path......: ./www/
o: HTTP Listen Address..: (null)
o: commands.............: enabled
i: Starting Camera
Encoder Buffer Size 81920
/root/bin/webcamd: line 105: kill: (499) - No such process
Goodbye...
Starting up webcamDaemon...
camera: raspi
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Dec 4 09:57:15 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
OctoPrint 1.7.2
Python 3.7.3
OctoPi 0.18.0
