Logitech C922
The camera stream (both in the OctoPrint UI, and through the /webcam/?action=stream stream) is not matching the quality / FPS as the /boot/octopi.txt settings. The stream skips a frame every now and then.
The logs suggest that it is running at 1080p, however the framerate definitely does not feel like it's running at 30fps.
I have tried changing the settings in /boot/octopi.txt however it does not seem to change anything.
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 30
raspi options: -fps 10
http options: -w ./wwwExplicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: $
<13>Feb 8 00:26:15 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1920x1080 -f 30 -d /dev/video0
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 30
i: Format............: JPEG
o: www-folder-path......: ./www/
o: HTTP Listen Address..: (null)
o: commands.............: enabled
OctoPrint version: 1.7.3
