Camera stream not loaded, but stream is ok
Cheap model from AliExpress: 6.49€ |Webcam USB haute clarté 12,0 MP 6 LED, veilleuse, caméra Web, micro intégré pour PC portable | AliExpress
The camera stream is not loaded, but when I click on teh stream URL it show the image in the new tab of the browser.
the url of the stream is http://HomeLab.local:8001?action=stream
My installation came from GitHub - paukstelis/octoprint_deploy: Bash script for rapid deployment of multiple octoprint instance on a single machine
I run octoprint in a Lenovo thincentre M910q with debian 12
I'm a totally newbie it's the first time I install octoprint, so I don"t know where to start
yes
Nope
octoprint-systeminfo-20240505002813.zip (16.2 KB)
Check your browser's error console for the reason why it is not loading.
You also cannot mix hostnames & IP addresses or http/https connections within the same page. So if you access OctoPrint via IP, then the browser will not let you embed something that comes from a hostname.
Thanks for the reply
When I inspect the browser console it said that the stream has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space private
One of the fix would have been to use https, but since I don"t know how to do that (yet), the easy fix was in the browser flags (eg chrome://flags ) disable Block insecure private network requests
And it works, know I can see the stream in octoprint :slight_smile:
