So some more interesting data. It looks like I'm only getting 1 partial frame and then something is crashing/failing as I need to restart the camera-streamer-libcamera service each time after loading the stream.
The web shows the one frame with the green rest of the scene. If I do it with VLC it momentarily opens a video window then outputs
Your input can't be opened
VLC is unable to open the MRL 'http://octopi.internal.roe.st/webcam/?action=stream'. Check the log for details.
into the errors and warnings window.
I turned on debug logging and see this in the VLC log
mjpeg debug: MIME boundary not found in 40960 bytes of data
main debug: Buffering 0%
mjpeg warning: no more data
mjpeg error: no EOL
main debug: EOF reached
main debug: looking for text renderer module matching "any": 3 candidates
main debug: Stream buffering done (0 ms in 0 ms)
main debug: using text renderer module "freetype"
main debug: looking for video converter module matching "any": 16 candidates
swscale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
main debug: using video converter module "swscale"
yuvp debug: YUVP to YUVA converter
main debug: using video converter module "yuvp"
main debug: Deinterlacing available
main debug: deinterlace -1, mode auto, is_needed 0
main debug: looking for vout window module matching "any": 1 candidates
macosx debug: Opening video window
macosx debug: Releasing old IOKit other assertion (39295)
macosx debug: Activated assertion NoDisplaySleepAssertion through IOKit (39297)
macosx debug: toggle playlist from state: removed splitview 0, minimized view 0. Event 2
macosx debug: toggle playlist to state: removed splitview 0, minimized view 0
macosx debug: returning videoview with proposed position x=0, y=0, width=992, height=736
the camera-streamer-libcamera log on the machine has
Aug 08 16:30:43 octopi sh[1572]: util/http/http.c: ?: HTTP listening on 127.0.0.1:8080.
Aug 08 16:30:43 octopi sh[1572]: /usr/bin/camera-streamer Version: 0.2.5 (41d8dfd)
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.054433885] [1572] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+82-2783c8d8
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.086842640] [1591] WARN RPI vc4.cpp:383 Mismatch between Unicam and CamHelper for embedded data usage!
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.087674592] [1591] INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/imx219@10 to Unicam device /dev/media4 and ISP device /dev/med>
Aug 08 16:30:43 octopi sh[1572]: device/libcamera/device.cc: CAMERA: Device path=/base/soc/i2c0mux/i2c@1/imx219@10 opened
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.088380046] [1572] INFO Camera camera.cpp:1033 configuring streams: (0) 1437x1080-YUYV
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.088870798] [1591] INFO RPI vc4.cpp:565 Sensor: /base/soc/i2c0mux/i2c@1/imx219@10 - Selected sensor format: 1640x1232-SBGGR10_1X10 - Selected un>
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.090551387] [1572] INFO Camera camera.cpp:1033 configuring streams: (0) 1437x1080-YUYV (1) 3280x2464-SBGGR10_CSI2P
Aug 08 16:30:43 octopi sh[1572]: [0:09:29.090987048] [1591] INFO RPI vc4.cpp:565 Sensor: /base/soc/i2c0mux/i2c@1/imx219@10 - Selected sensor format: 3280x2464-SBGGR10_1X10 - Selected un>
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: CAMERA:capture: Using: 1437x1080/YUYV, buffers=2, bytesperline=2880, sizeimage=0.0MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: CAMERA:capture: Opened 2 buffers. Memory used: 5.9 MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: CAMERA:capture:1: Using: 3280x2464/BG10, buffers=2, bytesperline=4128, sizeimage=0.0MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: CAMERA:capture:1: Opened 2 buffers. Memory used: 19.4 MiB
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device.c: SNAPSHOT: Device path=/dev/video31 fd=37 opened
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/buffer_list.c: SNAPSHOT:output:mplane: Requested resolution=1437x1080 is unavailable. Got 1437x1088.
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:output:mplane: Using: 1408x1056/YUYV, buffers=2, bytesperline=2880, sizeimage=2.9MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:output:mplane: Opened 2 buffers. Memory used: 0.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:capture:mplane: Using: 1408x1056/JPEG, buffers=2, bytesperline=0, sizeimage=4.0MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:capture:mplane: Opened 2 buffers. Memory used: 8.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device.c: RESCALLER:STREAM: Device path=/dev/video12 fd=40 opened
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:output:mplane: Using: 1437x1080/YUYV, buffers=2, bytesperline=2880, sizeimage=3.0MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:output:mplane: Opened 2 buffers. Memory used: 0.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:capture:mplane: Using: 992x736/YUYV, buffers=2, bytesperline=1984, sizeimage=1.4MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:capture:mplane: Opened 2 buffers. Memory used: 2.8 MiB
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device.c: STREAM: Device path=/dev/video31 fd=43 opened
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:output:mplane: Using: 992x736/YUYV, buffers=2, bytesperline=1984, sizeimage=1.4MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:output:mplane: Opened 2 buffers. Memory used: 0.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:capture:mplane: Using: 992x736/JPEG, buffers=2, bytesperline=0, sizeimage=4.0MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:capture:mplane: Opened 2 buffers. Memory used: 8.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device.c: VIDEO: Device path=/dev/video11 fd=46 opened
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:output:mplane: Using: 992x736/YUYV, buffers=2, bytesperline=1984, sizeimage=1.4MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:output:mplane: Opened 2 buffers. Memory used: 0.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:capture:mplane: Using: 992x736/H264, buffers=2, bytesperline=0, sizeimage=0.5MiB
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:capture:mplane: Opened 2 buffers. Memory used: 1.0 MiB
Aug 08 16:30:43 octopi sh[1572]: device/device.c: CAMERA: Setting frame interval_us=0 for FPS=15
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: SNAPSHOT: Configuring option 'Compression Quality' (009d0903) = 80
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: STREAM: Configuring option 'Compression Quality' (009d0903) = 80
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'Repeat Sequence Header' (009909e2) = 1
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'Video Bitrate Mode' (009909ce) = 0
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'Video Bitrate' (009909cf) = 2000000
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'Repeat Sequence Header' (009909e2) = 5000000
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'H264 I-Frame Period' (00990a66) = 30
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'H264 Level' (00990a67) = 11
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'H264 Profile' (00990a6b) = 4
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'H264 Minimum QP Value' (00990a61) = 16
Aug 08 16:30:43 octopi sh[1572]: device/v4l2/device_options.c: VIDEO: Configuring option 'H264 Maximum QP Value' (00990a62) = 32
Aug 08 16:30:43 octopi sh[1572]: device/links.c: ?: Link 0: CAMERA:capture[1437x1080/YUYV/2] => [SNAPSHOT:output:mplane[1408x1056/YUYV/2], RESCALLER:STREAM:output:mplane[1437x1080/YUYV/2>
Aug 08 16:30:43 octopi sh[1572]: device/links.c: ?: Link 1: SNAPSHOT:capture:mplane[1408x1056/JPEG/2] => [SNAPSHOT-CAPTURE]
Aug 08 16:30:43 octopi sh[1572]: device/links.c: ?: Link 2: RESCALLER:STREAM:capture:mplane[992x736/YUYV/2] => [STREAM:output:mplane[992x736/YUYV/2], VIDEO:output:mplane[992x736/YUYV/2]]
Aug 08 16:30:43 octopi sh[1572]: device/links.c: ?: Link 3: STREAM:capture:mplane[992x736/JPEG/2] => [STREAM-CAPTURE]
Aug 08 16:30:43 octopi sh[1572]: device/links.c: ?: Link 4: VIDEO:capture:mplane[992x736/H264/2] => [VIDEO-CAPTURE]
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: CAMERA:capture: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:output:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:output:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: SNAPSHOT:capture:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: RESCALLER:STREAM:capture:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:output:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:output:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: STREAM:capture:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:43 octopi sh[1572]: device/buffer_list.c: VIDEO:capture:mplane: Streaming started... Was 0 of 2 enqueud
Aug 08 16:30:47 octopi sh[1572]: util/http/http.c: HTTP8080/0: Client connected 127.0.0.1 (fd=4).
Aug 08 16:30:47 octopi sh[1572]: util/http/http.c: HTTP8080/0: Request 'GET' '/' 'action=stream'
Aug 08 16:30:48 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 574633528, vs 573586792.
Aug 08 16:30:49 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 575233536, vs 574186673.
Aug 08 16:30:49 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 575763525, vs 574719902.
Aug 08 16:30:50 octopi sh[1572]: util/http/http.c: HTTP8080/0: Client disconnected 127.0.0.1.
Aug 08 16:30:50 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 576363512, vs 575319784.
Aug 08 16:32:10 octopi sh[1572]: util/http/http.c: HTTP8080/1: Client connected 127.0.0.1 (fd=5).
Aug 08 16:32:10 octopi sh[1572]: util/http/http.c: HTTP8080/1: Request 'GET' '/' 'action=stream'
Aug 08 16:32:11 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 657482963, vs 656437161.
Aug 08 16:32:12 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 657982994, vs 656503809.
Aug 08 16:32:12 octopi sh[1572]: util/http/http.c: HTTP8080/1: Client disconnected 127.0.0.1.
Aug 08 16:32:12 octopi sh[1572]: device/links.c: RESCALLER:STREAM:capture:mplane:buf0: Capture image is outdated. Skipped. Now: 658613048, vs 657570273
