mjpg-streamer periodically starts dropping frames like crazy, even though I'm on a high-bandwidth wifi connection, and CPU and memory use are not pegged - not even close.
Others have seen this problem with mjpg streamer, and the dev can't isolate the problem.
Since the camera already outputs an mjpeg stream, is there any reason I can't direct that directly into the Octoprint UI? Any pointers to getting started?
Nexigo 980P USB web cam, formats from 320x240 to 60P HD, streaming from index0: RGB mjpeg stream.
Camera already outputs mjpeg stream. Can I bypass mjpg-streamer?
Camera works beautifully - except when it doesn't - there's a likely mjpg-streamer issue, which others have reported.
Tuning camera settings to try to prevent mjpg slowdown
webcamd.log
Starting up webcamDaemon...
ls: cannot access '/boot/octopi.conf.d/*.txt': No such file or directory
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1280x720 -f 10 -d /dev/v4l/by-id/usb-Sonix_Technology_Co.__Ltd._NexiGo_HD_Webcam_SN0001-video-index0
raspi options: -fps 10
Explicitly set USB device: /dev/v4l/by-id/usb-Sonix_Technology_Co.__Ltd._NexiGo_HD_Webcam_SN0001-video-index0
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was set in options and found in devices, starting MJPG-streamer with the configured USB video device: /dev/video0
<13>Jan 20 14:42:08 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1280x720 -f 10 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 10
i: Format............: JPEG
i: FPS coerced ......: from 10 to 30
o: HTTP Listen Address..: 127.0.0.1
Done bringing up all configured video devices
syslog mjpeg-streamer lines:
Jan 20 03:33:39 nutrimatwifi streamer_select[433]: No streamer type is set. Defaulting to 'mjpeg'.
Jan 20 03:33:39 nutrimatwifi streamer_select[433]: Setting streamer type 'mjpeg'.
dmesg re: camera
[ 31.715687] cam-dummy-reg: disabling
[ 94.883651] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[ 94.997142] usb 1-1.4: New USB device found, idVendor=3443, idProduct=980a, bcdDevice= 1.00
[ 94.997172] usb 1-1.4: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 94.997189] usb 1-1.4: Product: NexiGo HD Webcam
[ 94.997204] usb 1-1.4: Manufacturer: Sonix Technology Co., Ltd.
[ 94.997217] usb 1-1.4: SerialNumber: SN0001
[ 95.073303] usb 1-1.4: Found UVC 1.00 device NexiGo HD Webcam (3443:980a)
[ 95.078896] input: NexiGo HD Webcam: NexiGo HD Web as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
[ 95.079327] usbcore: registered new interface driver uvcvideo
[ 95.119806] usb 1-1.4: 3:1: cannot get freq at ep 0x84
[ 95.165614] usbcore: registered new interface driver snd-usb-audio
OctoPi bullseye v1.0.0
OctoPrint 1.8.6
Raspberry Pi 4 Model B Rev 1.1, 4GB RAM
