Camera with pi zero 2 w
Leekwi IMX219
Im a newbie and can't get it to work
I changed a line and added a line in the config file per manufacturer instructions
No i don't know how
I don't know. I don't know how to.
What does this mean
Newest, sunlu s8 pi zero 2 w
Click on the blue link :slight_smile:
Same here. Make sure to upload the zip file - don't just copy the text :tentacle:
You shouldn't need that. The can should work out of the box.
Which one? There are two images.
Is there cable fully inserted with the black/blue part facing up and the contacts facing down?
Hi I thought I would delete this post and start over. But i guess I can't do that. I've learned how to do the questions correctly now. Can i start over with the correct info? Sorry for my ignorance but I'm learning.
Thanks Steve
Just upload the bundle here in a new reply.
I am running ver 1.9.3 with new camera stack
Here is my system bundle
octoprint-systeminfo-20231016184749.zip (25.2 KB)
It does not look like there are any cameras detected by your Pi. I would double check all the connections are correct and the cable is facing the right way in both ports.
Thanks for helping. I'll check my connections
Thanks to everybody for the help, i got it working.
