I want to use my mobiles wifi hotspot as a network and connect my raspberry pi to it.
but it doesn't works. how can I solve this problem?
The answer to the post title:
Can I connect my raspberry pi to a mobile wifi hotspot?
Is yes, there should be no problems connecting a RPi to a hotspot, the same way any other device is connected.
With 'doesn't work' you will have to go into some more detail. Do you see the Pi connected?
the problem is that my RPi is RPi ziro without built-in wifi .
so I used a wifi dongle for it's wifi . but still it doesn't works.
I think I should change some setting of RPi . can you tell me how can I do that?
thanks in advance.
