- Octoprint No Longer boots
- Cannot SSH into Pi
- Printer was working fine, no configuration changes. Was able to connect prior to issue, uploaded a new .gcode to print. Power cycled Pi and turned on printer, Octoprint never came back up.
- Rebooting multiple times (No Change)
- SSH Via Putty (Fails)
- Win SCP Connection (Fails)
- Plugging Pi into a monitor and looking for error codes (Potato image attached with some errors that appear after letting boot for some time)
- Using another Pi with the Octoprint Micro SD (Current Octoprint Pi is a Model 3B, replacement Model 2, was a long shot, but nothing happened. )
- Clearing Browser Cache (No Change)
- Put SD into computer to look at files locally (Could not decipher issue)
- octoprint.log attachedoctoprint.log (9.2 KB)
- serial.log attachedserial.log (148 Bytes)
- Unknown where to find versions in file directory, but can provide if pointed to the right file.
- Ender 3 running latest Klipper
- Tried on two different windows 10 machines running Chrome Browser
