I had installed the 1.8 version and had the problems listed in the forums, so I followed the directions to revert back to 1.7.3. After that I can no longer drag and drop files from my computer to the webpage to upload them. I have to click the "upload" button to add the files. The webcam also freezes after a few seconds. If I reload the webpage, it will show again for a few more seconds, and then freeze again.
Not sure what to try.
Yes
No, same issues.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1800.0
env.hardware.ram: 1909264384
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5
env.plugins.pi_support.octopi_version: 1.0.0
env.python.pip: 22.1
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.safe_mode: True
octoprint.version: 1.7.3
systeminfo.generator: zipapi
Octoprint 1.7.3, after downgrading from 1.8. Ender 3 V2.
Could you try another browser / another device an check if you got the same issue there?
If it works on other browsers/ devices try to clear your browser cache.
I decided that maybe it just needs a fresh install. I wasn't worried about the plugins or files, so I got the 2022-01-28-octopi-bullseye-armhf-lite-1.0.0.img image from the downloads page. I used the Raspberry Pi Imager to install the image to the card and started the Pi back up.
Now the webpage won't work, and I get the " The OctoPrint server is currently not running" page. I ran the command given there and got the proper results, although "python" was in red at the end of the /home/pi/oprint/bin/python.
I did an FTP into the Pi and saw that the python folder wasn't there. What do I do now?
I have an update. For some reason, the page started working again. And I can upload by dragging and dropping the files onto the page. The webcam still freezes after a little while, which it didn't do before. It's not an expensive camera, it's just this cheap webcam.
For the record, that is an release candidate of OctoPi. I'd strongly recommend against using that unless you intentionally want to help in testing a future release. Instead, use the stable version of OctoPi, it is kept up to date and ships right with OctoPrint 1.8.0.
