I can not install any Plugins.
restart, update and downgrade PIP
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 912703488
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.9.3-20231009151442
env.plugins.pi_support.octopiuptodate_build_short: 2023.10.09.151442
env.python.pip: 21.3.1
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2024-03-28T19:02:06Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.9.3
printer.firmware: Marlin SkyNet3D-V2.3.2 (Github)
systeminfo.generated: 2024-03-29T10:53:23Z
systeminfo.generator: zipapi
Any Suggestions what i can do about this problem? I use this raspberry only a couple of weeks and also installed plugins at the beginning without any problems.
Here the Pluginlog:
2024-03-28 19:44:55,473 /home/pi/oprint/bin/python -m pip --disable-pip-version-check install file:///tmp/tmp7eo8n20v/release.zip --no-cache-dir
2024-03-28 19:44:58,502 > Looking in indexes: Simple index, piwheels - Simple index
2024-03-28 19:44:58,503 > Processing /tmp/tmp7eo8n20v/release.zip
2024-03-28 19:44:58,503 > Preparing metadata (setup.py): started
2024-03-28 19:45:01,173 ! error: subprocess-exited-with-error
2024-03-28 19:45:01,174 !
2024-03-28 19:45:01,174 ! ร python setup.py egg_info did not run successfully.
2024-03-28 19:45:01,174 ! โ exit code: 1
2024-03-28 19:45:01,174 ! โฐโ> [26 lines of output]
2024-03-28 19:45:01,174 ! Traceback (most recent call last):
2024-03-28 19:45:01,174 ! File "", line 2, in
2024-03-28 19:45:01,175 ! File "", line 34, in
2024-03-28 19:45:01,175 ! File "/tmp/pip-req-build-yx9jwnqx/setup.py", line 18, in
2024-03-28 19:45:01,175 ! miniver_version, cmdclass = get_version_and_cmdclass(r"octoprint_octorelay")
2024-03-28 19:45:01,175 ! File "/tmp/pip-req-build-yx9jwnqx/setup.py", line 15, in get_version_and_cmdclass
2024-03-28 19:45:01,175 ! spec.loader.exec_module(module)
2024-03-28 19:45:01,176 ! File "", line 790, in exec_module
2024-03-28 19:45:01,176 ! File "", line 228, in _call_with_frames_removed
2024-03-28 19:45:01,176 ! File "octoprint_octorelay/_version.py", line 8, in
2024-03-28 19:45:01,176 ! from setuptools.command.build_py import build_py as build_py_orig
2024-03-28 19:45:01,176 ! File "/home/pi/oprint/lib/python3.9/site-packages/setuptools/command/build_py.py", line 15, in
2024-03-28 19:45:01,176 ! from setuptools.lib2to3_ex import Mixin2to3
2024-03-28 19:45:01,177 ! File "/home/pi/oprint/lib/python3.9/site-packages/setuptools/lib2to3_ex.py", line 12, in
2024-03-28 19:45:01,177 ! from lib2to3.refactor import RefactoringTool, get_fixers_from_package
2024-03-28 19:45:01,177 ! File "/usr/lib/python3.9/lib2to3/refactor.py", line 25, in
2024-03-28 19:45:01,177 ! from .pgen2 import driver, tokenize, token
2024-03-28 19:45:01,177 ! File "/usr/lib/python3.9/lib2to3/pgen2/driver.py", line 26, in
2024-03-28 19:45:01,177 ! from . import grammar, parse, token, tokenize, pgen
2024-03-28 19:45:01,178 ! File "", line 1007, in _find_and_load
2024-03-28 19:45:01,178 ! File "", line 986, in _find_and_load_unlocked
2024-03-28 19:45:01,178 ! File "", line 680, in _load_unlocked
2024-03-28 19:45:01,179 ! File "", line 786, in exec_module
2024-03-28 19:45:01,179 ! File "", line 918, in get_code
2024-03-28 19:45:01,179 ! File "", line 587, in _compile_bytecode
2024-03-28 19:45:01,180 ! ValueError: bad marshal data (unknown type code)
2024-03-28 19:45:01,180 ! [end of output]
