if the webcam firmware doesn't work, you could also use rtsp firmware and utilize restreamer. I've documented the process of installing that on a pi here.
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Jul 19 03:34:30 root: Starting USB webcam
It seems that you don't have VL805 (Raspberry Pi 4).
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
<13>Jul 19 03:34:32 root: Starting USB webcam
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
<13>Jul 19 03:34:34 root: Starting USB webcam
Yeah I downloaded the RTSP firmware for the camera. For PuTTY, ill put the ip in and it will connect and ask for the login which I will put the login as "pi" then it asks for the password but that is when it freezes. I have never been able to type the password in. I always get the error.
