I get errors on two Octoprint Raspberry PIs when I try to update The Spaghetti detective. It errors immediately after it starts.
Restarted the Pi
2020-07-10 14:41:19,797 - octoprint.plugins.softwareupdate - INFO - Starting update of TheSpaghettiDetective to 1.3.1...
2020-07-10 14:41:19,842 - octoprint.util.pip - ERROR - Error while trying to run command /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/TheSpaghettiDetective/OctoPrint-TheSpaghettiDetective/archive/1.3.1.zip --no-cache-dir
2020-07-10 14:41:19,845 - octoprint.plugins.softwareupdate - ERROR - Update of TheSpaghettiDetective can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 1060, in _perform_update
update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
2020-07-10 14:41:20,149 - octoprint.plugins.tracking - INFO - Sent tracking event update_failed, payload: {'to_version': u'1.3.1', 'from_version': '1.2.5', 'target': u'TheSpaghettiDetective'}
Raspberry Pi Octoprint v1.40, AnyCubic Mega-S, Chrome browser, Windows 10 Pro
